Question about Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
Dryer stops before clothes are dry, lint filter light comes on. Cleaned all parts and used vinegar on drums as recommended in manual. This worked for for a while, but now it doesn't. Dryer starts and stops before clothes are dry.
  • 5 more comments
  • dampdrawers Dec 15, 2007
    I don't think there is a vent line, it's a ventless dryer. Any other thoughts?
  • jdaedelus Dec 02, 2008
    My dryer will dry for about 20 mins or so then it just stops and all my sensors flash. The heat exchanger is clean, and the areas accessible to be cleaned have been. I have also cleaned the sensors with vinegar as recommended. For awhile the sensors worked fine, but with time the dyer stopped functioning properly
  • Anonymous Mar 16, 2014
    lint light remains on and dryer does not dry clothes
  • Anonymous Mar 21, 2014
    dryer lights come on and will start then the drum and motor stop then keep restarting. Never continuously moving to dry clothes, just keeps stopping.
  • Anonymous Mar 23, 2014
    The dryer stops after 1/2 hour of running but the clothes are still wet. Lint filter, hose have been cleaned.
    I cab't remove the lint filter from he2 dryer..electric dryer
  • Anonymous Mar 30, 2014
    I have a beaumatic clothes dryer BVD50 can anyone explain to me how to remove the filter at the front of the machine, note; NOT the internal filter, I need to clean it but can't find a service manual anywhere on the internet.
I had the same problem with the lint alarm going off all the time; replaced the gasket and bought a new lint filter but neither helped. Finally I took a flashlight and inspected the back of the inside of ththe drum and noticed a little bit of lint in some of the little holes back there. I took some tweezers and extracted about half a thimble full of lint, and the dryer has worked like a charm ever since.
Posted on Jun 02, 2012
    Problem Solver:
  • 8 Answers
Have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
  • Master101 Dec 16, 2007
    Have you pulled the heat exchanger in the bottom of the dryer and checked it ? also make sure the air intake is not blocked or stoped up is there a good supply of fresh air the dryer is not closed up due to cold weather ?
Dryer not starting
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
Feb 27, 2010 | Bosch Axxis WTL 5410 Electric Dryer
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
2,063 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
