Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag top laoder stacked washer LSG1000
The washer fills fine washes but when it empties the water out it dumps it on the floor looks like the water comes from inside not any of the hoses on back can see bottom of washer looks like is where water comes from. What could cause that??
Susan
  • Susan Fox
    Susan Fox May 20, 2008
    turned out it was the belt came off the water pump
  • 145 Answers
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Posted on Apr 24, 2008
I have a roper heavy duty extra large capacity washer the water comes into the machine fine but runs out just as fast, it won't fill up.
Go direct to the maker. This sounds like the pump is running continuously, or do you mean it empties on the floor?
If the latter, a hose has come adrift or split/perished?
Welcome to Roper Home Appliances
Sep 12, 2015 | Roper Washing Machines
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
Quiet pak 4 shows code 20 it will fill up and wash 2 minutes before it throws a code
"F20" error code is indicating that no water is detected entering the machine or the pressure switch trip is not detected. If after 30 seconds of filling with water and the minimum of 0.11 of water is not detected entering or the maximum fill time of 16 minutes is exceeded, the valves will turn off and the error code will be displayed. It is an indication that you either have no water coming into the washer, or very little water at all. If you have verified the water pressure is fine, you may have a faulty Flow Meter. You could remove the cold and hot water supply lines, after shutting the water off of course, at the washer and then look to see if the filter screen is restricted inside the water inlet valve on the washer.
The first would be to blow through the pressure switch hose towards the tub. You should be able to blow through the hose without much force. If the air trap the hose is hooked up to is blocked then the pressure switch will not see the water entering the tub. With the tub empty blow through the hose and then hook it back up and see if there is any improvement.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Kenmore Washing Machines
Same complaint but my washer is FULL of water that will not drain
Take the drain hose off the back and dump it into a bucket , make sure that you remove any clips on the hose so that it lays down flat
It will take several buckets but the machine will empty
Turn off the water supply to the machine and see if it will do a spin cycle once it is empty
If it does then turn on the water to the machine with the power turned off , if water runs into the machine then the fill valve is shot and needs to be replaced.
If it starts and stops filling via the turning on and off of the power then you have a problem with the pressure switch or Air Bell and that needs a man who can
Jul 17, 2009 | Washing Machines
Simpson enduro 701 overflow and dumping water on floor
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 06, 2009 | Washing Machines
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Maytag washer performa is over filling with water.
Bad water level switch or pinched hose going to water level switch.
Feb 21, 2009 | Maytag Performa PAV2200
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
293 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
