Question about Palm TX Handheld
In ternal broken screen (TX Palm)
My hand held TX palm fell and the internal screen cracked, the palm itself still works, but the screen is blank with the cracked design on it.
  • Anonymous Dec 26, 2007
    My palm tx touchscreen cracked a while ago. LCD works fine, but I have leaf like gray area in the middle of the screen where I can't see the central part of my screen. Stylus still works even on the gray area, everything else functions well. I am not sure if I should fix this or buy a new one.
    Novelist:
  • 94 Answers
It's up to you whether you can live with the damaged screen or not. If you have a service plan, or the repair is cheaper than the replacement, get it fixed. Just my 2 cents. At some point you'll get fed up that you can't see something and you'll chuck the poor thing at a wall and break the rest of it...
Good luck.
PS - An impact that can damage the LCD may have damaged other internal components. It's worth having it looked at sooner rather than later.
Posted on Jan 03, 2008
My Palm TX is not showing anything on the display. The hot sync is working. Only has Blank White screen. What is going on?
Hard reset. Hold the power button as you reset. Be careful, because it will erase everything on the pda.
Jan 28, 2010 | Palm TX Handheld
I had a power flicker during the time I was hot syncing my Palm TX. The hot sync did not work, and it would not hot sync at all after that. On advice from Palm's website, I downloaded the latest desk...
If so much has happened to your handheld then the only thing left to be done is a reinstall of the firmware, as that is the only solution to a corrupt firmware because of the power glitch while it was doing something. The glitch has corrupted the firmware and thats how it needs a reinstall. Nothing serious but such things do happen i electronics.
Nov 02, 2009 | Palm TX Handheld
I have the same problem! I use to get on just fine.
Try doing a hard reset. Make sure you have everything backed up on your pc since you will have to do a hotsync once you do the hard reset. OK to do a hard reset do this:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen2.gif.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Sep 18, 2009 | Palm TX Handheld
Is there anyway to delete programs from a Palm TX from the desktop?
HI,
Yes there is a way to delete programs. Take your TX and in the upper left of the screen you will see the time. Tap the time with your stylus. A drop down menu will appear. Tap "DELETE". Your TX will generate a list of all the programs and applications on your hand held. Once that list is generated tap or highlight the one you want to delete and the tap the delete button at the bottom of the screen. Once you have deleted all the programs you want tap done and then do a hot sync. They should be gone from then on. If you find this helpful please rate me. Best wishes.
Sep 14, 2009 | Palm TX Handheld
Have to reset Palm TX to power on sometimes
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Sep 09, 2009 | Palm TX Handheld
Hard rest plam tx
Here are the steps to do a hard reset. Best wishes.
1. Press and hold down the power button.
2. While holding the power button, use the tip of the stylus (or similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm Power logo to appear and then release the power button.
Aug 18, 2009 | Palm TX Handheld
I forgot the password for mine, how can i get around this to cancel or even change the passwprd?
If you have forgotten your password you should be able to use the password hint to figure out what it is. You can try a soft reset to see if that will clear the password but I am pretty sure this won't help. To do a soft reset use the tip of the stylus or something pointed like a paper clip and inset it in the hole on the back of your palm pilot. This will make the unit reset it's self. If this doesn't help then you must preform a Hard rest to continuing using your hand held. You need to make sure that you have all your information backed up on your computer as a hard reset will erase everything on your hand held. Here are the steps to do a hard reset:
3. Wait for the Palm Powered logo to appear, and then release the power button.
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen.
Aug 05, 2009 | Palm TX Handheld
Palm T/X touch pad not responding
pls reset the device like this and then align it
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=7125,E=0000000000337448967,K=6865,Sxi=8,case=obj(887)#hard
if problem persists then yes u are gettin screen alignment problem bcoz of digitizer fault it is faulty u want to do it then go to below link
buy the digitizer and change it urself see the video
http://www.gethightech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PA1693&Category_Code=_TUNG
PLS RATE ME FIXYA FOR THE HELP
Mar 20, 2009 | Palm TX Handheld
Broken lcd
If you live in the US or Canada you can take to any Best Buy store and they can tell you your options.
This link from Palm.com will give you other support options if you live outside of North American
Jul 23, 2008 | Palm TX Handheld
Palm TX
do you have a screen protector? if so, i suggest checking to see if there is anything caught between it and the screen. there might be a speck of dirt or whatever that is causing that. also check for dirt accumulating around the edges.. hope that helps. good luck
Jun 06, 2007 | Palm TX Handheld
Palm TX Handheld Logo
64 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
