Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Gas heater I have a roof model airconditioner/gas heater. The trouble is, when it gets cold enough at night, the gas heater kicks off but no heat. I have to turn it off at the thermostat and back on, then it starts to warm up. Had the same problem with the old setup. The heater/airconditioner is new and have a new thermostat but the same old problem.
  • joeblow123 Dec 15, 2007
    thermostat is not mercury, it is an electronic. it's the second one I've tried. seems to happen when it gets really cold at night or during the day. Blower is working but no heat. I turn it off and on at the thermostat and the heat comes back on.
SOUNDS LIKE YOU COULD HAVE A BREAK IN ONE OF YOUR THERMOSTAT WIRES.IS IT A MERCURY TYPE THERMOSTAT?MY E-MAIL ADDRESS IS HYBRIDMOMENTS1977@YAHOO.COM JEFF.
Posted on Dec 15, 2007
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
Lennox whisper heat gas furnace blows cold air,
As others have said, furnaces require a lot of maintenance. It sounds like a number of things could be causing the problems you've had. A professional would likely be able to pin point the problem and get it fixed.
John Cribbs ' Heating Maintenance Services Salt Lake City UT
Nov 13, 2012 | Heating & Cooling
My libertys heater only blows heat when I'm giving
first off all if a/c gas presssure is low or no gas at all ( because of some reason you have already lost it) it acts exactly how you you describe. kicks in and out. but cant cool air inside. (first make dealer check it for leaks and let them fill it with proper yellow flourescent dye added gas)
limited het in cabin heater is another issue. if engine is warm and still not enough heat inside, we can say that you have a clogged cabin heater or air pocket is in hoses connected to cabin heater. you need to bleed cooler radiator inm front. you need to raise infront of car and bleed it with bleeding screw. after this check the heat again if still not enouh heat you may need to replace cabin heater.
if engine is not warm enough when you drive slow or let it idle. this means you have a broken thermostate or it is stuck half open.
Aug 02, 2011 | 2003 Jeep Liberty
WHY DOES MY RHEEM RBHC-14J11SFD BLOW ONLY COLD AIR? THE AIRCONDITIONER WORKS, HOWEVER THE HEAT DOES NOT TURN ON. THE THERMOSTAT IS SET TO ON AND TO THE HEAT POSITION.
Heat pumps tend to blow a much lower temperature outlet air than a gas fired unit would. Is this your first year with this furnace?  Depending on your outside temps, an auxiliary heat strip may not be operating properly.
Jan 05, 2010 | Heating & Cooling
I have an old cozy natural gas heater that cuts off at night
Remove and clean all electreical connections in the unit.
Dec 26, 2009 | Cozy Heating & Cooling
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Code 11 01 - Hot Water Heater Kicks Off
if you have build up in the heat exchanger it will cause the unit to use more gas to heat your water, if the gas line isn't sized properly then your going to kick the error codes off. it sounds like you have two problems, first you have build up in your heat exchanger and it needs to be flushed and second you need to get a bigger gas line to it
Aug 19, 2009 | Water Heaters
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Feb 25, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Dont want that cold cuz iam already ther
The heater element sensor are open or fuse/ motor ok /flow of air ok heater is the problem.replace fuse or heat sensor if open.
Jan 08, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
88 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
