Question about Standard (CRT) Televisions
Bang and Olufsen TV - stopped working
We had a power brown out. All other TV stuff still seems to work.
TV will not power up. Digital/ LCD display no display.
Has 120 volts going into TV
  • 51 Answers
SOURCE: Analog odr Digital?
the problem you are having is a loose solder connection on vertical ic,easy fix only soldering vertical you need solder iron and solder. but yes your tv is analog and will require a digital converter.
Posted on Jul 10, 2008
0 characters
1 Points
Bang olufsen mx7000
Check for any loose solder terminals at its video output card. This card can be located at the back of the CRT, will directly plugged on to it. Re-solder all the suspected solder terminals, by applying a little more solder. The fault can be categorized to 'sigle color predominant' screen.
Gopakumar Gopalan Google
Feb 12, 2014 | Standard (CRT) Televisions
I have a Sony KD-34XBR960 and the standby light blinks twice and makes a click noise and a bang sounds off in the back of the TV and then it repeats its self , the TV does not turn on .
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
    Pull up older posts. You can get all details.
    Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
    Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Jun 02, 2012 | Sony FD Trinitron KD-34XBR960 34" TV
Switched itself on and off and then went bang and stopped working
You have a power supply problem and high voltage issue, this will require a tv technician to inspect the set because it is a specialty repair, and I would suggest an estimate, because from your description it will be expensive.
Jan 09, 2011 | Samsung DLP HL-P5663W 56" TV
My 42inch plasma bush tv made a load bang noise as i was watching it yesterday. The picture immediately dissapeared, but the sound stayed.
That sounds like the plasma power supply section has stopped working.
Replacement module probably. Fairly expensive, maybe, unless there are some refurbished panels out there.
Hope that helps.
Jan 04, 2011 | Bush Standard (CRT) Televisions
32 inch prima lcd tv model lc-32u16 that won't turn on
You probably have some defective filter capacitors in the power supply. The tops of them may be domed instead of flat. Be sure to replace them with same values listed on the originals - slightly higher voltage rating is OK, but no less! Make sure they are rated at 105 degrees C and not 85 degrees.
Apr 02, 2010 | Prima C2012 TV
I have just been given a Panasonic TC-29V26A colour TV in perfect working order. I connected my Digital box to it and had no problem, I just can't get any non digital channels to tune in...even following...
U only get digital channels,that work propperly notthing wrong.Get a digital antena might all the other digital not getting.Non digital will not tune in any more.
Feb 10, 2010 | Standard (CRT) Televisions
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Standard (CRT) Televisions
Tv doesn't come on
The brown stuff you see is excess flux and is not hurting anything,you need to check the horizontal output transistor for a short,sometimes this transistor goes bad because loose conections in the horizontal driver transformer and could have been intermitant,if the transistor is shorted it likely took the safety resistor that gives him the volts to operate.It seem you are familiar with tv service but some measurements need to be made with a meter to check for a short.If the transistor is bad it need to be replaced with an exact replacement,check for loose conection anyway very carefully,some are hard to see.
Oct 06, 2006 | RCA 32F531T 32" TV
Standard (CRT) Televisions Logo
51 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
