Question about Maytag Neptune MAH5500B Front Load Washer
Wont do anything
My neptune washer, display turns on and everything but won't do anything after the power went out during a storm i press every button on the membrain and othing happens any advice will be helpful
    New Friend:
  • 25 Answers
I'm sorry to hear that, your motherboard is likely fried. But just to be sure, try unplugging the washer and then plugging it back in. I suggest you check out the manual for the troubleshooter. There is a myriad of sites that provide them like this one Maytag Neptune Washer manual. Hope this will help ;)
Posted on Nov 21, 2013
    Scholar:
    New Friend:
  • 36 Answers
It is a long shot, but better than nothing...unplug your unit for a full two minutes (recommended by manufacturer's owners manual). This will allow any stored energy in the circuit board to dissipate and may allow your circuit board to "reset" when you plug it back in. Then give it a try.
Posted on Dec 19, 2007
MY maytag neptune dryer center wont start when I press the start button on the bottom unit it shows PF
The PF is a power failure code and it indicates the control is not sensing any line voltage
Check the circuit breaker for the dryer is not tripped. The PF could be caused by a voltage drop during a storm but you should be able to clear it and run the dryer
Oct 14, 2016 | Maytag Dryers
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Feb 26, 2016 | Maytag Neptune MAH9700 Front Load Washer
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My washer has passed all the diagnositc test BUT when running through a simple quick cycle it keeps beeping E3
e3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 02, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Had a lightning storm,now brand new aircon wont restart,remote is ok
The electrical storm may have caused a power surge and burned out the circuit board. Especially, if the power went out briefly and then came right back on. Most manufacturers recommend turning the unit OFF during a power outage/electrical storm.
Hope this helps you.
Mar 25, 2011 | Heating & Cooling
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag m7y12f2a stopped working is their any reset buttons
All devices that have circuit boards or digital displays need a surge protector or turn off during storms. If none of the functions or dispays don't come up, there may be an inline fuse on the panel. More than likely the board or transformer is fried. For that you need a Tech.
Jul 09, 2009 | Heating & Cooling
Maytag Neptune MAH5500B Front Load Washer Logo
208 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
