Home | Toshiba | 43H71 43 in. Rear Projection Television | Tv was blurry them tur...
Toshiba 43H71 43 in. Rear Projection Television
Problem for Toshiba 43H71 43 in. Rear Projection Television
Tv was blurry them turned off and wont come back
By deadaugust69 on Sep 23, 2009
tv was blurry them turned off and wont come back on and the red light on front blinks
Solution #1
posted on Sep 23, 2009
Not Rated)
sams_trix
Rank: Wiz
Rating: 85%, 39 votes
The blurry must be defined as out of convergence or out of focus,If there is a lines of color on the pictures edges, its convergence, if the picture is not sharp the focus is the problem.The common cause of convergence problem is the convergence drive chip(stk) and might be the cause of shutdown too.The focus problem is commonly contributed by the projector lenses, in most cases the coolant liquid leaks and drip on the board, this causes shutdown too.The lenses must check first for any leak before the replacement of IC(stk).
Was this helpful?
Yes
No
Popular Solutions for Toshiba 43H71 43 in. Rear
Questions and Unsolved Problems for Toshiba 43H71 43 in. Rear
Do you recommend Toshiba 43H71 43 in. Rear Projection Television?
Answer
Answer
the picture is messed up- the colors are separate and shadow-like.
Answer
tv will turn on but have no picture. the power light does not flash just stays constant
Answer
Toshiba flat panel model #PDP42X3 shows no picture but has static sound is it fuses? How do I know... (More)
Answer
toshiba tp61f90 no picture when i hook up cable to either tv video 1 or 2 standard cable jack. if i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 43H71 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
