Question about HP Compaq Presario CQ50-103NR Notebook PC
Got power, frozen machine
I can't seem to get this laptop to boot. It froze while I was watching a DVD. The fan was on full blast and that's when I got nervous. There isn't a reset button and it would not respond to ctrl, alt + del so I switched off the power. Now, the computer wont boot. It will read a DVD but the disk led will not come on to let me know if the cpu is reading my harddrive. I have taken out the battery and powered down. I removed the cmos batt and rebooted and nothing, the laptop will not reboot.
    Problem Solver:
  • 10 Answers
okay what you need to do is if you have the system restore cd use that , it will reformat your lap top even if it cant reboot just put in the cd when you start up the computer and it will restore everything you may lose alot of things but atleast your lap top will work after , if not then Reply to me at Jonk3y at Aol.com and i will gladly help you with your problem
Posted on Sep 23, 2009
SOURCE:
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using...
Make sure the cooling fan for the laptop is not obstructed in any way or is not dirty. It's pretty common for a laptop to get plugged with dirt from normal use. Get a can of air and blow the machine out to remove dirt, lint or debris.
You could also have a defective battery, but try cleaning the machine first.
Feb 24, 2011 | Computers & Internet
HP Pavilion DV6700 won't boot
Possibly overheating? As you say that when you press and of the F-Key option nothing is happening, and also the fan is running at full power, if the fan is louder than usual, then it could be overheating in the air vents which you can find either at the sides, back, front and underneath the laptop, try getting the compressed air, and giving the air vents a blast to get all dust out. Or a vacuum. Do it whilst laptop is turned off though!
Jan 26, 2010 | HP Computers & Internet
Toshiba laptop stuck
try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Sep 30, 2009 | Computers & Internet
Freeze when power cord plugged in
the problem is in the battery of your laptop.
change the battery of your laptop.
to make this shure, just remove the battery from laptop and turn on power through adapter only. it will work fine.
dont forget to vote
Sep 14, 2009 | Toshiba Satellite A205-S4617 Notebook
Device powers on but will not boot
I have seen this happen when the amount of RAM installed in the computer is higher than what is allowed by the motherboard.
Jun 28, 2009 | Acer Aspire 5315-2153 Notebook
Pre-recorded dvd won't eject/entire system frozen
Try unplugging the machine so it will reset itself. Then plug it back in. That has worked for me in the past.
pjrsop
Mar 24, 2008 | Samsung DVD-VR357
T30 startup problems...
We can start with the easy stuff first. Move the memory chip to the other slot. Remove the small square plate on bottom of the laptop. You'll need a really small screw driver for this. If you have two chips, remove one and see if the laptop will boot-up.
Jun 28, 2007 | IBM ThinkPad T30 2366 Notebook
Home Theater Philips HTS3410D Audio problem
your sytem is going into protection power regulayor ic needs to be renewed
Sep 04, 2006 | Philips HTS3400/37B System
HP Compaq Presario CQ50-103NR Notebook PC Logo
126 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
