Question about Car Audio & Video
Replacing front and rear speakers in a 1999 Mazda Protege
How???
  • Anonymous May 14, 2009
    should the grill pop right off in the front door?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Whats the problem?
Back - Remove speaker grill, unscrew, climb in trunk, unplug - remove.
Front - Remove speaker grill, unscrew, pull out, unplug. If you have problems remove window winders and door skins
Posted on Feb 12, 2008
2 Suggested Answers
budice7h20
  • 93 Answers
SOURCE: Will 2 KENWOOD KFC-6982iE fit in 1999 mazda protege
If they fit then put them in. The only thing is, if your not using a amp they may not sound good.
Posted on Jul 02, 2009
How do I replace the interior trunk light to a 1999 mazda protege? Is there even one to replace?
if there was one
it will be under the rear parcel shelf
get to it from the boot
one can be wired in or stick in a led battery light there
Nov 06, 2016 | 1999 Mazda Protege
Wiring scymatic for stero
1994 Mazda Protege Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Red
Car Radio Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Sep 07, 2012 | 1994 Mazda Protege
What are the factory size speakers for a Mazda Familia Hatchback 1995 (3 door)
This vehicle is also marketed as the Mazda 323 and Protege. There is no listing for a 3 door Protege for 1995. For the 1995 sedan the speaker sizes are 6.5" for the front and 6x9 for the rear. There is no listing for a 1995 323 (which is a 2 door hatcback)but, the 1994 323 has 6.5" speakers for the front and rear.
Aug 01, 2012 | Car Audio & Video
Replaced Headunit with after market one, but now the dash lights don't work, Fuses are fine, everything else is fine. Car is 1999 Mazda 323
Hi, there is a factory wire (red with a black stripe) in your car for illuminating the stock radio. This wire is not to be used in an aftermarket radio, so you need to make sure it isn't connected and also isolate and bare wire with electrical tape. Please let me know if you have questions, and thanks for using FixYa.
1999 Mazda Protege Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Yellow/Blue
Right Front Speaker Negative Wire (-): Violet/White
Car Audio Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Orange
Right Rear Speaker Positive Wire (+): Green/Orange
Right Rear Speaker Negative Wire (-): Green/Black
May 03, 2011 | 1999 Mazda Protege
Mazda protege rear strut replacement 02
they're underneath the plastic deck cover in the back, where the speakers are. -just a few plastic fasteners and the wire connector for the rear light, and it'll pop right off. -just did it myself this weekend
Jan 03, 2010 | 2002 Mazda Protege
Jul 01, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Mazda protege 1999 rear brake replacement
Have you adjusted the adjuster to bring the shoes close to the drum? Always force the pistons in (the return springs should hold them in) and then adjust to make a tight fit after replacing. When the shoes are on right, there is no way for the piston to come out, as there is only a quarter inch of travel.
Jul 27, 2017 | 1999 Mazda Protege
Radio Speakers
Its possible that some wires are loose, considering both rear speakers are not working and not just one. Your best bet is to check for any loose wires behind the front deck or behind the rear speakers.
Apr 15, 2009 | 2001 Mazda Protege
1999 Mazda Protege balloint
that nut is welded on the frame hopefully its not strip because yes you have to drop the frame good luck pierre
Sep 17, 2008 | 1999 Mazda Protege
Car Audio & Video Logo
934 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
