APC Smart-UPS RM 1500VA USB & Serial  UPS System
Problem for APC Smart-UPS RM 1500VA USB & Serial (SUA1500RM2U) UPS...
The ups supply power from battery even when the
By mushew on Sep 23, 2009
the ups supply power from battery even when the mains power is present problem:
Solution #1
posted on Sep 24, 2009
Not Rated)
tech240
Rank: Wiz
Rating: 80%, 28 votes
It is common on budget systems that to maintain operational windows on UPS supply the inverter can be supplied by the mains and the battery so the unit will cope with the low extremes of input volts.
You may of course have a rectifier fault which would also cause a similar situation.
If the batteries charge ok in the normal time, then this is unlikely.
All of these cheaper units are difficult to repair, they are full of surface mount components and unless it is a simple fault, it is likely to cost more than the unit to investigate the fault and repair it.
APC units come with powerchute software, maybe use this to see if it reports any faults, or offers some other information.
Hope this helps, thanks for using FixYa
Was this helpful?
Yes
No
Solution #2
posted on Sep 23, 2009
Not Rated)
pagebor
Rank: Wiz
Rating: 83%, 1671 votes
your ups needs to be serviced
Was this helpful?
Yes
No
Popular Solutions for APC Smart-UPS RM 1500VA USB &
Questions and Unsolved Problems for APC Smart-UPS RM 1500VA USB &
Do you recommend APC Smart-UPS RM 1500VA USB & Serial (SUA1500RM2U) UPS System?
Answer
Answer
how do i manage usb 2 port hub my hub is not recognize by the computer
Answer
My handle on my paper cutter broke... can it be replaced?
Answer
please advise where i can repair samsung usb of 8gb in ernakulam.
Answer
my zyxel usb moems are not picking up the router signal,.but my laptop is..what am I doing wrong??
Answer
alarm led and utility led are flashing all the time for r5500 ups
Describe your UPS Systems Devices problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top UPS Systems... Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
