Question about U-Line 75R Refrigerator
Not working After some minor in-house flooding, the 75R was in 3 in of water, the unit has stopped working. What would be a few items to check?
  • 410 Answers
Check all wiring connections in the affected area for corosion or broken wiring. if i'm not mistaken the temp control may be in the rear unit compartment as well so if wiring and connectors are ok, it poss the cntrl is bad
Posted on Dec 19, 2007
SHE44 pump keeps trying to empty but there isn't any water
she44-pump-keeps-trying-empty-but-isnt-3dor230cw2fd2t5j4bvk0sa4-4-1.jpg Hello. First, when looking up info on your model, I came across this recall on the SHE44C unit. Check your model number and serial number to verify if your unit falls into the recall range. (fire hazard)
Next, study the schematic diagram for your unit--the drain pump is connected directly to the main board--the fact that it's running even with the door open suggests that the main board might have a stuck relay and will have to be replaced if that is the case. The part number is 444813. The drain motor (see close-up, pic 4, is designated M3) has one side wired to the board, the other side goes through the on/off switch to incoming power, (see pic 3, lower right corner). I hope this helps you!
Sep 26, 2015 | Bosch Dishwashers
Watersoftener salt tank keeps flooding
Sounds as if the head has a valve sticking, Need an overhaul kit that has new paddle valves with screen and injector also. Unplug unit, put into by-pass (3 valves above it) then manually rotate cam to depressurize head and tank, follow kit instructions to overhaul, or you may want to call a plumber.
Jan 02, 2014 | Water Reservoir
We had a storm and now the phone lines in the house to not give a dial tone. We did have minor flooding in the basement. I checked the outside box and there is a dial tone there. Also our doorbell is...
Check to see if you "minor" flooding watered a jack or you have a cable lying in the water or got wet. Examine the pins on each jack and cord. Or, as an alternative if you can unplug all but the main phone from the jacks (assuming there are modular jacks for each extension) then plug them in one at a time until the problem comes back, you may be able to pinpoint the bad cable run.
Carl
Aug 21, 2011 | Lands Phones
Dishwasher is working fine however at the completion of the cycle and when it sits idle it seems to be flooding from under the filter area.Flooding is slow however but causes headaches when it breaches...
Your water fill valve is slowly leaking water into your dishwasher. Your need to turn off the house water valve, to your dishwasher, and see if the problem stops. If it does then replace the dishwasher water fill valve. If it doesn't stop, then you have water coming in through your drain lines, which is highly unlikely. You will have to check to make sure your drain line has a high loop in it, or install an air gap. Good luck, Appliance Specialists
Mar 13, 2011 | LG 24 in. LD-12BW5 Free-standing...
Coleman model APW-120 May have frozen while stored over winter the unit is new but water was not completly removed before storage. Problem motor runs continuosly but there is no water pressure I have...
Whar has happened is that your unloader / bypass valve is sticking. This is due to minor corrosion and having water in the unit over the winter. Most of the time they will sanp out it if you do the following:
Add 3 - 4 oz of oil into the water supply connection and briefly and I mean very briefly switch on the unit then right back off. Add more oil to the water supply connection and then let it sit overnight.
Then next day turn the unit on briefly and let it sit another 30 minutes. After this you connect all hoses making sure to purge the air our of the supply hose BEFORE you connect the to the unit. Then once you turn the unit on rapidly trim cycle the wand trigger. Your goal here is to cause a water hammer of the unloader / bypass valve to get the spring and cupped seal to move in the housing. Pause briefly and see if pressure builds then fan the wand trigger again. This can take a few minutes to get it to work but the routine of pausing waiting momentarily and rapidly tripping the wand trigger is what should get the unit going again.
If this does not work you will have to take the unit apart dis-assemble the unloader / bypass vavle on the output side of the pump and remove the corrosion on the spring and the housing.
Once your done cleaning up the bypass unloader valve before you put it back in the housing place a liberal amount of Lubriplate #105 White Grease on the spring and inside the housing on the mating surfaces. (#105 white grease is available at any Auto Parts store. It is in a 3 - 5 oz plastic tube)
Re-assemble the unloader / bypass valve an it should work like a champ.
Thanks for choosing FixYa.
Kelly
Sep 16, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Small refrigerator stopped working 75r
You have 2 wires. Unplug and put wires together. Plug unit back in and check to see if everything is running. Doesnt matter where the wires go with a 2 wire thermostat
Oct 09, 2009 | U-Line Uline Origins Series...
Lighns on - nothing else
well i have a 75r also with the same symptoms but there's no freezer in this model so I don't know how it could be the defrost timer.
Dec 03, 2007 | U-Line 75R Refrigerator
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Water overflow
Are you on a well? Often people with a lot of sediment in water get sick of the screens in water valve plugging up so they remove them. NEVER remove these screens. If any sediment gets into valve it can hold it open causing flooding. If you unplug unit and water still comes in you must replace valve.
Oct 08, 2007 | Maytag LSE7806A Top Load Stacked...
U-Line 75R Refrigerator Logo
83 people viewed this question
Top U-Line Refrigerators Experts
Marvin
Marvin
Ilia Bichin
ray gallant
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
