Question about Amana ABB1921DE Bottom Freezer Refrigerator
Amana refrigarator it's not holding the cold anymore -----even when set on low
    Scholar:
  • 27 Answers
Hi. The most common failure for this make refrigerator is a bad evaporator fan motor. You should feel air coming out of the diffuser in your freezer. If not, either the fan motor is bad or you have alot of frost build up on the evaporator. You would see alot of frost on the back wall of the freezer where the evaporator coil is located. If this is the case, most likely the defrost bimetal thermostat. But if no frost, the evaporator fan motor is most common and likely to be your problem. Also check and make sure your compressor is running. Compressor failure is common on this make refrigerator. Visit me on Ebay username: themackshack. Good luck! Mack
Posted on Mar 23, 2008
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
My LG Model LP0910WNRY2 will not get cold even though the compressor turns on
check the outside and see if its blowing cold air out of condensor otherwise low on freon.
Jun 28, 2014 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
Not cooling
Unplug it, and don't turn it on anymore. Doing so can damage the compressor, and I hope it is not damaged already. This will cause the compressor to overheat, and fail. You can buy line tap, and then buy one of those 134 adapter. Check to see if it has freon in there. Refrigarators today uses 134 and anyone can buy it. Locate the low side which is the larger tube coming out of the compressor. Screw in the tap, which should poke a hole on the line. Dont worry a tap do not leak, and I have used them many times.Once in place push the valve if there is any freon in there. if there is none then there is a leak somewhere. Find the leak and repair it first. You can buy a cheap propane torch for about 12-20 bucks, along with flux, and some solder. make sure you clean the copper to be repaired first with a wire brush. Once the leak is repaired, you are now ready to put the 134 refrigerant. An average refrigarator usually take a little more the half a can of 134. Putting too much will not make it cold enough. Well good luck hope this hepls.
Jun 27, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ABB1921DE Bottom Freezer Refrigerator Logo
162 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
