Question about Philips 30PF9975 30 in. LCD HDTV
30pf9976 philips lcd tv
After turning on it clicks, the standby led is green after a few seconds it clicks again and then the standby led turns red and flashes continuously there is no sound or picture
4 Suggested Answers
  • 90 Answers
SOURCE: Did you ever get your Philips fixed?
that specific flashiing is the software in the computer, the television has inside
you need to go to the philips website and download an upgrade software repair it is free-- put it on a thumb drive without any other things on it---- the television ,must be on to install --- turn it on with the remote and then insert the thumb drive-- the television will run a scan--- then turn off television and wait a few minutes-- turn it back on with the switch on the side of the unit-----
the power problem is something else--- the power board sounds like is going bad--- a new one is around 300-400 and a rebult unit is around 100 --- you can find them on
this television is poorly built -- when you get the new board it is easy to install -- before ordering a new board -- check the fuses on the board-- there are two fuses -- one is 1amp and the other is 5amp -- both are slwo burn fuses
Posted on Feb 24, 2009
  • 19396 Answers
SOURCE: Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
  • 5 Answers
SOURCE: Philips 20PF4121 LCD tv no picture but flashing error codes
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Posted on Sep 23, 2009
  • 8457 Answers
SOURCE: I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Posted on Oct 22, 2009
0 characters
1 Points
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Turns on, lower right shows "DIGITAL TELEVISION"
Good day!!!
That problem is usually cause of bulged capacitors on the power supply board..
This the sample picture of your power supply board and I marked the possible problems on capacitors..
Things you will need.
1. A plastic flat end screw or any object with flat fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps..
Feb 02, 2012 | Sylvania LC420SS8 LCD TV
After turning of the TV for a few minutes, it won't turn ON. The power LED turns green for a second and then becomes red and flashes, Philips Model 32PF7321D/37
grodmx74, You or electronics technician will need to find the "thermally-intermittant-hair-line-fracture" of a component soldered to the switch-mode-power-supply printed circuit board with aid of large magnifing glass or use a 10x or 20x inspection microscope, and then resolder the connection. 12fixlouie
Apr 02, 2010 | Philips 32PF7321D 32 in. LCD Television
I bought my son a 19" philips tv model # 19pfl340d/ order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
My LCT3201AD is plugged in and the standby light under the screen is on (red LED). Repeated attempts using both remote and side Standby/Power switch result in the LED turning green for only a few seconds...
Remove the power supply and replace the three (3) capacitors soldered to it. They will be rated at something in the neighbrohood of 16v. Replace them with larger capacitors, something in the neighborhood of 35v.
Jul 11, 2009 | Akai LCT3201TD 32 in. LCD Television
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Akai LCT3201TD
Most failures of this nature are with dying or defective power supplies.
I service these power supplies. If you need more info, my email is
Oct 14, 2007 | Akai LCT3201TD 32 in. LCD Television
Philips 30PF9975 30 in. LCD HDTV Logo
49 people viewed this question
Top Philips Flat Panel Televisions Experts
Are you a Philips Flat Panel Television Expert? Answer questions, earn points and help others
