GE Deluxe AGM05LA Thru-Wall/Window Air Conditioner
Problem for GE Deluxe AGM05LA Thru-Wall/Window Air Conditioner
Hello would the Goodman CPLE18-1c and CPLE30-1
By okon5327 on Sep 23, 2009
Hello would the Goodman CPLE18-1c and CPLE30-1 model work on a 220voltage. It says on the machine AC volts 208/230. I want to purchase both of them, however, I would like to know if it would work whenI ship it to Africa.
Best Solution
posted on Sep 23, 2009
Very Helpful)
rolingking
Rank: Wiz
Rating: 84%, 218 votes
Yes, of course, it will work, since it is rated 208/230. Does it come with a 208 and 230
selector switch?. Then you can set it at 230v.
If none, then it will operate well between 208 to
230 volts. That means that 220v is within range.
E-mail me if this help and please don't forget
to cast your vote for me in Fix Ya.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you for your answer. It will enable my decsion making onthe product. " - okon5327
Solution #2
Helpful)
rhozel2010
Rank: Wiz
Rating: 83%, 112 votes
Hi! from the specs. you have given i think it will work. because your voltage requirement fit the voltage specs of the unit.
Was this helpful?
Yes
No
Asker's Testimonial
" Thank you. I thougth it would. " - okon5327
Solution #3
Not Rated)
fougzki
Rank: Wiz
Rating: 85%, 289 votes
It is the effecient working voltage of the unit. It should work not below 208 volts or above 230 volts.
Was this helpful?
Yes
No
Popular Solutions for GE Deluxe AGM05LA
Questions and Unsolved Problems for GE Deluxe AGM05LA
Do you recommend GE Deluxe AGM05LA Thru-Wall/Window Air Conditioner?
Answer
Answer
select knob for friedrich heat and air unit switch from heat to air .greensboro,nc27403
Answer
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a... (More)
Answer
Conia 3 HP, 5 yr old air conditioner/ had split system outdoor unit serviced recently, re-gassed,... (More)
Answer
when you set the temp it will show you 70 but then it goes to EP and does not cool . This unit is... (More)
Answer
I have a GE window air conditioner with eletronic thermostat and remote control. It is probably 3 or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Deluxe AGM05LA...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
