I cannot find where the water filter is located on my Whirlpool ED5CHQXKB04 Refrigerator.
The filter on a ED5CHQXKB04 uses a line filter: http://www.repairclinic.com/PartDetail/Water-Filter/4378411RB/1603265
Usulay the filter is in the bottom grill for the fridge on right side. You just need to twist counter clockwise to remove.
that particular fridge uses a line filterhttp://www.repairclinic.com/PartDetail/W...
SOURCE: water filter whirlpool fridge
look on the bottom kickplate for a round peice unscrew it and replace the filter
SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
SOURCE: can't find the water filter on my admiral refrigerator
You should have a filter in one of two places the back of the fridge or under your sink
SOURCE: location of refrigerator water filter
The filter should be a canister somewhere in the line from your sink to the refrigerator. If there is no canister visib;le there then obviously they never installed a filter in the first place. I hope this helps. Don't forget to rate my answer. thanks.
SOURCE: water is dripping into refrigerator
If it's the same as our GE fridge, there's a tube in the back of the fridge on the outside with an S shaped curve in it that may be plugged up with dust and/or dirt. Clean it out to let the water get through.
Hope this helps.
Johnnyczar
