I have an Amana model srd25s5e. It not cooling properly any more. Turned up to the Max it only cools the Fridg. to 44 degrees & the freezer to 26 degrees. Cleaned the front of the screen over the coils, but didn't seem to help. Is there some other place to clean the coils that I missed or is it time for a new refridgerator.
there is a couple of things you can try. you can try to defrost the whole unit. it is not always a good idea to turn it up to the max setting. if the inner coils get frozen up it causes the problem you are having.
Was this helpful?
Yes
No
Popular Solutions for Amana ASD2625KE Side by Side
I changed the water filter ran several pitchers of water as directed. The filter ok light does not...
(More)
I changed the water filter ran several pitchers of water as directed. The filter ok light does not light. Is this a problem? I pressed the water & lock buttons as directed but the ok light still doesn't light. The larger green light above the filter indicators is light.
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new...
(More)
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new 9 years ago. After checking my owners manual I decided it needed a good cleaning, so i took all food out, pull it out from wall, cleaned the condenser coils (lots of dirt) cleaned the condenser fan (lots of dirt)unplugged and open both doors for 24 hours,, started it back up and it worked great for 12 hours-got cold- made ice- cold water from dispenser... then it stopped (no cold air) no water coming out of dispenser,, turned off for 4 hours and then started it back up,,, worked great for about 12 hours and then stopped again, HELP any ideas?
I took it out to fix it because the bar that turns the ice came off. The front assembly with the...
(More)
I took it out to fix it because the bar that turns the ice came off. The front assembly with the blades came apart and I dont know how it goes back together.
