JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My AV-56WP74 JVC projection TV will not converge the red, out of alinement. I did manuel convergence-which let me go up and down, but not side to side. So how would I get rid of the red blurr?
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Sep 23, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1183264
Points
12747
You need to replace the convergence chips which have become duds
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
1helpful
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jvc 56wp74
sounds like a solder related issue on the convergence ICs. They are acessed through the front of the TV behind the speaker grille and then remove the small acess panel and you will see the convergence amp board with the two ICs on it.
Convergence problem with my jvc tv
Its actually a easy repair but its recommended that the convergence resistors need replacement as well. You can get the parts at the following link and they provide free detailed instructions with pictures. You need two STK392-110 Convergence ICs and you would need the JVC convergence Resistor kit #1 also. Heres the link.
http://servicemanuals.vstore.ca/
Red Convergence
all you gotta do is use the manual convergence if only the red is messed up
JVC I'Art AV-56wp74
A repair facility will charge 400 to 600.00 for the repair. Or you can repair it yourself if you can solder. As both convergence ICs need to be replaced. They are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair yourself. Heres the link.
JVC AV-56WP74 Red Convergence is Off
Sorry,I don't send E-mail instructions......see my powered
products for many convergence repair solutions........T.
JVC projection tv
Mike, convergence adjustments are in your menu, usually under "video" settings. You have to adjust red & blue onto the green, when you`ve done it correctly the "cross" will be pure white, if you cannot move either of the colors left, right, & up, down then the convergence IC`s have failed and will have to be replaced, hope this answers your question, BMW Rider
Convergence problem
I have this exact model TV, and my red bulb was the primary culprit. I almost had it, but then a lot of fluid came from underneath the bulb? I had to turn it off in fear of electricution. Ended up selling the TV.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
