Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 5150 - solid amber light at the switch.
Bought it for 17 months, now have this problem. Solid amber light at switch and nothing happen.
Unplug all cards, memory, cables and plug all back and power on, this time green light at the switch and nothing happen. Switch off power and switch on again, now again soild amber light. Have tried unplug one card at one time and power on.
Please advice on this problem.
  • 1 more comment
  • emmanuelakpa Sep 24, 2008
    amber stay solid, and can turn pc on
    Thanks
    emmanuel
  • Anonymous Mar 14, 2014
    the power light on my dell optiplex 990 is solid amber and "234" is flashing amber
  • Anonymous Mar 19, 2014
    system will not turn on with 2,3,4 light in front flashing green and power in solid amber
    Sergeant:
  • 239 Answers
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
Posted on Dec 15, 2007
I had this problem and bear001's comment solved it!
Posted on Jul 30, 2010
This is Telling you battery has gone bad, I had that same problem
Posted on Jan 07, 2008
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Dell troubleshooting
Most likely there is something wrong with either the motherboard, cpu, or RAM. Check out the troubleshooting steps at:
http://bit.ly/ZRBZvZ
Jan 28, 2014 | Dell Inspiron Computers & Internet
Dell poweredge 2650 solid amber light
go here and enter the service tag of your server and download dell open manage server administrator managed node. once installed it will tell you exactly what the problem is. i believe the current version of OMSA is 7.1
Dec 10, 2012 | Dell PowerEdge Computers & Internet
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Pc has a solid amber light when i try to turn it on now so i unplugged it. I moved the comp around and turned it on again and it had a solid green light but nothing was on. the third time it went back to...
Hi Thanks for your question
I think you are right about power supply. This would be my diagnose. Be careful with your PC because faulty power supplies may fry your motherboard. I would recommend replacing it. This isn't expensive and it's pretty easy to get done. I hope this helps. Good Luck
May 19, 2010 | Dell Dimension 4400 PC Desktop
Dell dimension 5150 Diagnostic Lights 31 BLINKING 3,4 SOLID
Hi you've either got the wires on the wrong connectors or they need to be turned around, i.e. red needs to be where black is. Hope this helps
Mar 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 3100 when switching on light goes from green to orange as does screen nothing else happens
A flashing AMBER power button normally indicates a failure of the Power Supply. Solid Amber is often the Motherboard
Jun 22, 2008 | Computers & Internet
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
2,880 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
