Question about NetGear FVS318 Cable/DSL ProSafe VPN Firewall Router
How to install netgear fvs318 vpn firewall?
I need help in installing a netgear fvs318 vpn router firewall between an actiontec dsl modem and a netgear wnr834b wireless router?
  • 854 Answers
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Sep 16, 2009
  • 83 Answers
SOURCE: can a actiontec gateway wireless DSL router be
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Posted on Nov 08, 2009
  • 5 Answers
SOURCE: actiontec GT701WG ROUTER
If you cannot connect to the router through 192.168.0.1, do a harware reset - I think there is a button in bach and use the factory default user/password. Then just disable the wireless in setup, advanced, wirless settigs - click Wireless Off radio button. And change the password.
Posted on Apr 17, 2008
serra_baby
  • 144 Answers
SOURCE: INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Posted on May 01, 2008
2Gigs
  • 141 Answers
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
  • 151 Answers
SOURCE: where do i find UPnP
The netgear prosafe VPN router is a high-end component ment for business and corporate use and does not support UPnP
UPnP (Universal Plug and Play) allows programs accessing your router (limewire, utorrent, etc...) to auto configure the security settings on your router which would be harmful to a business/corp. network.
Posted on Aug 11, 2010
I am trying to install my FVS318G
If you just plug it in - it should work. Are you using DSL or Cable - in either case just plug router WAN PORT into modem and then plug computer into and LAN PORTs on the router. Now configuring the unit is a different question
Aug 08, 2012 | NetGear FVS318 ProSafe VPN Firewall -...
Why is it that when i connect to prosafe vpn i am unable to connent to web pages
It probably has something to do with the fact that this particular model is not meant for personal use, but in big corporations. It does not support UPnP which allows possibly harmful programs that are accessing your router to auto configure the security settings on your router. If you got any more problems with your router, maybe you should check out this cool users manual. It really helped me a lot, maybe it will help you, too :)
Jan 09, 2011 | NetGear FVS318 Cable/DSL ProSafe VPN...
Where do i find UPnP on the the fvs318 netgear prosafe VPN firewall router, i cant find it on the main configuration menu
Aug 11, 2010 | NetGear FVS318 Cable/DSL ProSafe VPN...
Netgear FVS318 Question
Yes, it can provide keyword blocking and website url additions. For a higher end solution in the same family you can also look at the FVS538.
Mar 30, 2009 | NetGear FVS318 Cable/DSL ProSafe VPN...
New computer, router dropping sites?
Log on to the router and make sure that these sites haven't been placed in a block list for whatever reason.
Check the Netgear website for firmware updates required.
Feb 20, 2009 | NetGear FVS318 Cable/DSL ProSafe VPN...
Connecting the GT704WG DSL modem/router
disable your firewall temporarily to see if the firewall is what causing the problem, are you using windows firewall.??
Feb 17, 2009 | Actiontec GT704WG Wireless Router...
New high ping/latency issue, Netgear FVS318.
I don't know if you still need help but did you try upgrading the firmware? Do you have the server and computers setup with a DMZ?
Dec 14, 2008 | NetGear FVS318 Cable/DSL ProSafe VPN...
Won't let me connect to PlayStation 2 online
no need to turn off the router's firewall... just forward the ps2 port number on the router. make sure you manually assign static ip address to your ps2.
Jun 25, 2008 | NetGear FVS318 Cable/DSL ProSafe VPN...
ActionTec not allowing RDP
There seems to be issues with RDP and VPN Routing with Actiontec Modems in that I can't get mine to work either unless I turn on DMZ hosting, and send all traffic to my Server.
Solution: Turn on DMZ Hosting and set the address to your desktop, warning, however, all traffic sent at your modem WILL be received by your computer, so make sure you have a good firewall installed.
Dec 11, 2007 | Actiontec (GT704WG) Router
Netgear Test Mode (remains amber)
hi sounds like thers not enough volt either on the DC input because of the y spliter - take an adapter for each one check again if there is a good line good luck
May 04, 2006 | NetGear FVS318 Cable/DSL ProSafe VPN...
NetGear FVS318 Cable/DSL ProSafe VPN Firewall Router Logo
710 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
