Error 6000 Hi there it is ink error. You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Start with printer off
Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
While holding the Power button, release the Resume Button.
Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
you can reset the error by doing, 1.hold RESUME then press & hold POWER 2. release RESUME, then press it twice, the light should go amber then green again. 3. you're now in service mode (you can release POWER now)
for waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once. Hope this helps. Please rate my response. Thanks. Have a good day.
What version of windows are you using? for windows 7 I had to right click goto properties and change the compatibility to windows vista so it would install. Need more info on what the error is and what update you did.
Your Operating System is corrupted, probably by a virus or a program you recently installed. The best solution would be to reinstall your Operating System (OS). Remember to back up your data before OS installation.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let
resume button go, then press resume button twice. Then let power button
go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power
will not come on, remove power cord from back of printer, then wait 15
seconds before plugging back in again and turn power on. This normally
solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been
disabled,the low ink warnings are showing againand they will have to be
disabled once more. This would indicate that the above procedure clears
the firmware memory of the disabling of the chips, this may be usefull
if you need some warranty work done on you printer after the chips had
been disabled. Canon does warn that disabling the chips may result in
the printer's warranty being voided
The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
Press and hold the Setup button.
Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
