Question about Patton U2-1487 Floor / Box Fan
Motor is siezed
Power to it, but motor shaft does not turn. Motor hums
Usually this means dirt/dust/debris has gotten into the bearings. Needs a lube job.
Posted on Jun 16, 2009
    Problem Solver:
  • 8 Answers
Agree with holloway. I've had to clean mine several times over the years. You'll have to take the motor apart, clean the shaft and housing of dust and gunk, then oil or WD-40 it and reassemble. Be careful to note in advance exactly how all the parts go back together.
Posted on Aug 25, 2010
What could be wrong,My pump wont turn on , it makes noise but wont kick on
open it up and see if the impeller will turn freely when it is disconnected from power. Call pool guy or pool store and see if it just needs a solenoid.
Sep 19, 2014 | Hayward 1.5 Hp Northstar High Performance...
Hayward Pump motor, hums but won't start. If I turn the shaft it will keep running but once I turn if off it will not run until I do the same thing again. I have replaced the capacitor but still the s
1 or 2 capacitors on this motor?
Sometimes there are two...
One is a "Start" capacitor and if a 2nd one, that one is a "Run" capacitor.
If only 1 capacitor and you have replaced it... if not a faulty capacitor, then your windings are shot?
When I test a motor with this symptom, I will use the "Clock Face" method of checking for "Dead Spots" on the winding/stator:
Once you have removed the shaft cap on the back of the motor, I presume you have done this since that is only way to turn the shaft manually to get it to run in the manner you described. Place a small mark (1/4" long?) on the outside perimeter of the shaft, say at the 12:00 position. See picture attached...
Then flip switch, does it start or hum?
Then rotate shaft until your mark is now at the 1:00 position. Flip power switch, running or humming?
Do this at all clock positions as you turn/rotate shaft until you reach 12:00 once more. If the pump hums at all clock positions completely dead motor or bad capacitor. If a dead spot is at only one clock position, then absolutely, bad motor - either rebuild or replace.
Coincidentally the motor may stop each time on a dead spot, where the motor won't start due to a fried portion of the stator/winding/armature, only a major repair fixes this. The purpose of the test is to place the position of the stator in a different position in relation to the windings. If humming all the way around, then possibly a bad capacitor, because it is not starting in any position. If it starts say at all positions except 4:00 and 9:00 then motor is bad.
Good luck
Aug 30, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Motor hums but not turn
could be the motor brushes, check for black powder on motor. could be a siezed motor, try turn it manually by hand.
Nov 18, 2013 | Asko Washing Machines
Washer stopped working with low humming noise
Belt may have broken or come off, or idler seized or main support bearing siezed or even motor bushings may have seized. Best access is from above to check.
If you can spin the drum with ease from the inside, the belt broke or is off. If it will not turn, the motor bushings may have siezed, or the main bearing siezed.
Apr 12, 2012 | Kenmore HE2 Plus Front Load Washer
My model 137.21990 bench top drill press, the electric motor will turn if I take the belt off the pulley but when I slip the belt back on the spindle the motor stops turning and just hums!! I shut it off...
The motor is not necessarily shot. It may be that the motor can't handle the load. Even with the pulley and belt assembled your running at virtually "no load". The problem may be that when you attach the belt it pulls the motor "out of true verticle" which in turn causes the shaft to sieze inside the motor housing. Try making sure the motor is square and aligned exactly verticle and it is secured firmly to the base plate.
Mar 05, 2010 | Measuring Tools & Sensors
Our hot tub uses a Waterway Pump. We emptied the water and refilled it with clean water. The pump now just hums... and doesn't pump. Did we do something wrong? Is there a solution. It is 220V. The...
Was the pump working prior to the cleaning or had it been sitting dormant? The motor relies on a starting circuit within it to operate. One of the components can be bad or the pump can be siezed up.
Turn off the power and remove the back cover from the motor. Try to turn the shaft by hand. Is it free to turn? If so, the problem is inside the motor. If not, look for the obstrction.
A local electric motor repair shop can help you if you find damage in the motor and/or pump.
Dec 27, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Outdoor unit hums but fan doesn't turn. Nothing heats up but the fan just won't turn and is there a spot to oil the fan on the motor
The fan motor on the outside unit should be a sealed motor. If the unit is just humming is the humming from the compressor or from the motor being locked up. You could try spinning it a few times with the power off to see if this might get it to run and spray some penetrating oil under the fan blade right where the shaft comes out to the fan blade.
Dec 24, 2009 | Heating & Cooling
Motor outside is humming like it on but the fan isn't turning
Sounds like the run capacitor is bad or the bearings or siezing up. Turn the power off to the unit, then spin the fan blade to see if it spins freely, if it does then it's probably the capacitor.
Jun 22, 2009 | Heating & Cooling
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Patton U2-1487 Floor / Box Fan Logo
563 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Tom Chichester
Are you a Patton Dryer Expert? Answer questions, earn points and help others
