Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsubishi vs 50707 50 inch projection tv problem
Picture is intially scrambled, like a horizontal hold problem. after a few minutes it unscrambles, but vertical columns can be seen in the picture if the background is dark. the problem on my tv has now escalated to where it turns itself off as soon as i turn it on.
  • barryg Jan 18, 2008
    I have the same TV with the same problem. White vertical columns that show up real clear when you have a dark background. Is this something that I can fix myself or do i need a tv repairman to do it???
    Any help would be appreciated.
    President:
  • 4,402 Answers
On the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
Hi I have the mitsubishi WD 62525 and I have replace all the bulgy capacitor, now the tv is working, but after a few minutes the picture start distorsionated to the point that is scramble. I turned off...
You have a multitude of surface mounted capacitors that have to be changed on the DVM module which is part of the Light Engine Assembly. Mitsubishi's are notorious for this problem. Mits charges $300.00 to refurb the Light Engine Assembly , which is not a bad price.
Dec 27, 2010 | Mitsubishi WD-62526 Projection TV
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS 50707 ( not 705)
I have the same TV built in 99. My problem is similar but the vertical hold gives out when the tv warms up about 5 minutes. I will attempt to locate the vertical hold circuit and replace any parts I suspects may be the problem. I suspect a cap is leaking or transitor around IC700 is degrading when warm.
Jul 31, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50707
Click here to get more info on the subject and also check the other links in that post.
Good Luck.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-50707 - Scrambled picture
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Nov 08, 2007 | Mitsubishi VS-50707 50" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi ws-55813 horizontal hold
When you say horizontally, do you mean it collapse or it scrambles. Because the 2 are different problems. If you pictures shrinks or collapse then it is in the vertical circuit. and if it scrambles itself almost like you can see the picture but it is broken up over and over again, then this is video problems in video circuit. Need more info
Aug 13, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Intermintent picture
Check the horizontal output transistor this could be damage and causing the problem.another thing is pilot light that cause the screen to light up.since this is a projection t.v.it does not garry a tube.
Jan 19, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
