Samsung HP-T4254 42 in. Plasma Television
Problem for Samsung HP-T4254 42 in. Plasma Television
Samsung tv clicking sound
By osvaldocapet on Sep 23, 2009
TV turned off by itself a couple of days ago, and will no longer turn on. It does a clicking sound every 3 to 4 seconds indefinitely. Called Samsung and was told it needed service, unfortunately TV is out of warranty, it 2 years old.
Comments:
Sep 23, 2009
- there are no bulging caps on the power supply like many other posts say to look for.... any ideas?
Best Solution
posted on Sep 26, 2009
Very Helpful)
Chu3505
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 85%, 527 votes
It ur power supply board it have components,is dead could be anythings,Capacitors bulbging happen mostly only on DLP Tv bacauce the FTB transformer,give high voltage for projection.Tries thes websites for replacement power supply board.Shopjimmy.com,Tv Repair World.com,Partstore.com or Ebay.com.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 23, 2009
Very Helpful)
pra0099
Rank: Wiz
Rating: 84%, 37 votes
Hey
your tv SMPS(switch mode power supply) and the switching IC section has a proplem......
you will need on site a Electronis digoniss engineer
it may have happened because of low voltage/electrical fluctution/and weak part if any/
but remember do not keep you TV on if you know there is problem.....it may worsten some times so doo keep unpluged always
There is internel problem
may be in trigger Transistor......and in the resistor.......it may require replacement.......
Haa (it also may happens due to low voltage supply in you place get the voltage supply in the pin socket of wall checked if according your country supply voltage)
Regards
let me know
Was this helpful?
Yes
No
Solution #3
Very Helpful)
tammysawisch
Rank: Master
Rating: 100%, 1 votes
yep needs servicing.it needs a new fuse or chip of some sort.
Was this helpful?
Yes
No
Popular Solutions for Samsung HP-T4254 42 in. Plasma
Questions and Unsolved Problems for Samsung HP-T4254 42 in. Plasma
Do you recommend Samsung HP-T4254 42 in. Plasma Television?
Answer
Answer
i have a hp t 4254. it randomly turns itself off and back on.
Answer
my tv is making a tweaking noise every minute or two
Answer
Have HP-T4254 that turns on and off continuously. Yesterday, I REPLACED the main power board on the... (More)
Answer
There is no picture or volume after we unplugged it for a while. The Logo lights up, but that's all.
Answer
when the power button is pressed the tv doesn't turn on
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
