Question about ASUS P4VP-MX Motherboard
System error loading
Im not good in repairing computer but ihave little bit of knowledge in comp?in my case im in other coutry so its hard to find where ican bring it to repair.so i try search for some solution.can u help me?when i start up my comp for formating it will promp an error on laoding operating system.what would be the prob of that is it OS or my mother board?
  • cajanjae Dec 18, 2007
    sory for late saying thanks.
    Genius:
  • 1,601 Answers
Try restarting and go to bios,set to default config.
Also,
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
See this article:
http://support.microsoft.com/kb/326676
Posted on Dec 15, 2007
Ihave a samsung dDVD player ht-d330k when I switch it on, it writes "prot"and immediately switches off. What should I do
There is an issue on the system board. Send it for repairs. Unless you're very knowledgeable about such matters, you're just going to damage it. I checked the manual, and that error isn't even listed.
http://www.theatresystem-manual.com/manuals/samsung/Samsung_HT-D330K.pdf
In the manual are also listed customer service phone numbers if you wish to call them. Good luck!
Aug 24, 2015 | Samsung Audio Players & Recorders
Error opening operating system
First try to use your operating system disk to repair the problem using operating system repair option.
If this does not work and you expirence the same problems you could try restoring your Operating System but first back up any files you would like to keep.
At any rate back up your files now! In case your hard drive is failing.
To do this get an external enclosure for your drive and load it up on another windows based PC then back up your files. If you have no important data then try a clean install of your windows version. it may take several drivers and updates not to mention hours but it will be done.
If it is your hard drive failing you should receive a message indicating this otherwise it could just be corrupt system files or improper installation or deletion of materials that are required for the OS to function.
If it is not this it could be something like your main board video chipset possibly overheating in which case you can try and have it repaired or buy a used working motherboard for your laptop and replace it with some patience and some hours and a little bit of cash you could have it back in working order.
May 26, 2012 | HP Computers & Internet
Why does startup repair keep popping up on my laptop when i turn it on my sony laptop
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
May 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Farmville said to refresh as game is slow or freezes the comp Ihave uploaded adobe again but does't work I am a fairly new user but age well let say mature
It sounds like you may not have enough memory in you computer to run farmville. I have 2GB in my computer and it runs a little slow when playing farmville.
Feb 27, 2010 | Acer Computers & Internet
How to put a file onto sandisk 2gb cruzer micro memory stick I haven,t much computer experience thanks
Im guesing this like a Jump drive and it is the same as mine what you need todo is plug it in to the comp and wait for the system to recognize it , Goto the computer folder and see if it register the drag an drop what you desire on the disk to be transported>(Presto you got it) Good luck its truely simple .
Remember your comp works for you.
Oct 18, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have Vista Premium 32 loaded on my comp, a Dell with an AMD dual core 64 proc'r. How can I load Vista 64? Do I have to format and start from scratch? All tests say my comp WILL support the 64 bit OS....
hey
if you are not advance user then I would not suggest you switch over to 64 bit operating system...however if you wish to switch over then in this case u can do dual booting depending on the harddrive partitions as you have dell so in this case dell have only 1 partition so you have to format the harddrive and then you have to start from scratch other wise it might give you conflicts
Sep 18, 2009 | Microsoft Windows Vista Ultimate Edition
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Still trying to restore my emachines comp. tried restore windows xp when prompted, it came back with error accessing file?
This error can show up during installation of the operating system either via the hard drive (the restore feature is located on the hard drive and shows up as a drive letter under My Computer) which indicates that you have bad memory,
OR
You are installing from a DVD or CD, in which case it could be either bad memory or a bad disk.
good luck
tony
Jun 08, 2009 | eMachines T2885 PC Desktop
Wont load correctly
check the hard drive.western digital hard drives work good in this computer. ihave two of them.also windows xp home works good on this.or run the system recovery cd.lastly' re do the
windows installation.
Jun 03, 2009 | Gateway Essential 400 PC Desktop
Computer won't work past login screen
from that error, it is likely one of 2 things. Either the bootloader is corrupted, which you can try to repair with the following tools:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+from+the+DVD
Worst case for a software error, clean install of Windows to resolve.
Or the hard drive is having a hardware failure and it is effecting the boot sector of the HDD. If it is a HW failure, you may be able to run diags to see if a fault is found. If the drive is bad, it will need to be replaced
Feb 05, 2009 | Acer Extensa 4620 Notebook
ASUS P4VP-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
