Question about KDS K717s 17" LCD Monitor
KDS usa k717
Everytime i turn off the monitor and turn it back on i see lots of different lines with different colors and you can hear the monitor making sounds... and i have to like put a peice of cardboard behind the cover of the outer layer of the monitor and hit the screen for it to come on... can anyone help?
  • Morph26 Jan 14, 2008
    I have the same issue, but at first I could temporarily fix the problem by switching the refresh rates back and forth from 60htz to 70htz to 75htz and back again. Unfortunately, it seems that the trick no longer works, and based on the advice of a friend of mine who is tech support, it has probably gone to the great display in the sky. If there is anyone with more info or a possible fix please let me know. thanks.
  • 64 Answers
Look at the capacitors on the power supply board. If any of the tops are not flat (raised) they are blown, replace them with similar values printed on the side. Also check the resistance between the legs of any transistor mounted to heat sinks, if you detect a short, reverse your leads, if the short is still there, replace the transistor.
Posted on Jul 16, 2008
Look at the capacitors, if any of them have bulging tops, they are blown. Replace them with the same values written on the side. Ohm out transistors mounted on heat sinks, none should have a short. If you find a short, reverse your meter leads and see if the short is still there, if it is, replace the transistor.
What to do about a power supply problem in the monitor?
Posted on Feb 21, 2008
  • 5 Answers
I have solved this for other LCD monitors, and have worked with other problems on this model. Most likely, the VGA signal is not reaching the controller chip intact. This will cause the mode detection to select the wrong resolution or continuously switch resolutions. If colors are missing or wrong, and the image is otherwise correct, then it is with the 3 analog color signals: red, green, or blue. This does not sound like your problem, so I suspect one or both of the two digital timing signals: VSYNC or HSYNC. Here are the troubleshooting methods and solutions:
1) Try the monitor on another computer to confirm a monitor problem!
2) Use a different VGA cable, in case it has an intermittent wire, or a bad connection.
3) Check to make sure that the light remains green. If off, the power supply is bad. If amber, the computer is not generating a signal, or the VSYNC and HSYNC are not arriving in the monitor.
4) If none of the above solves it, you will need to open the monitor. This is tricky. Remove the power cord. Remove the 4 philips screws on the bottom of the panel. Try to free the 3 "L" hooks on each side by pushing the bezel toward the top. You will probably need a thin and wide flat blade screwdriver to pop the case. Start sliding under the bezel from the bottom of the right hand side until it catches. A light twist will separate it. Slide up to next catch.
5) With power cord out, and bezel off, check the 15 pin VGA connector for corrosion and solder joints. Clean, replace, or resolder, as necessary. You can also check the cable from the VGA connector to the board.
Hopefully, this should allow you to fix the problem.
Posted on Jan 24, 2008
I bought a used KDS USA Monitor Model 780 Rad-7SI. Guy told me it works fine but I didn't make him hook it up to anything. I get a power light but screen remains dark. Are there drivers of something I...
If you are using a laptop, try to "toggle" between the screens I think it's the F4 key to see if it turns on...if you are using a desktop see if you have more than one output for video. If you do, try the other port. If not, try hooking up a different monitor to your comp to make sure the video out is working. If so, then with this monitor powered on, lean it back and see if you can see "shadowed" items on the screen. If you can see words or anything on the screen (like the windows startup screen when you first power up) then the light inside the monitor is bad. Hope this helps
Oct 23, 2013 | KDS Radius Computers & Internet
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
How do I return my KDS USA monitor back to factory settings for color?
The KDS has an 'OSD' ("on screen display").
Press one button on the front of the KDS to activate the OSD, and navigate through its various menu-items, to find the "reset" control.
Apr 16, 2010 | KDS K22mdwb LCD Monitor
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
Kds k717 screen is black what is wrong with it
The same problem happend on mine it was ac power converter box had to replace it twice but its been working for 3 years now note light was on both times
Nov 10, 2009 | KDS K717s 17" LCD Monitor
After 15min the monitor cuts off. KDS k717. Iturn it off for a few min and turn it back on and it does it again
power converter/supply bad defect contact manufactuer and ask for warrenty replacement
Mar 13, 2009 | KDS K717s 17" LCD Monitor
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Kds just two seconds
I have the sameproblem soI plugged in a HP 1702 after 2 days it started doing the same thing. I am using an old school kds with no problems.
Could it be a bug in the system with flat screens.
Jul 28, 2008 | KDS K717s 17" LCD Monitor
Monitor stays black
First make sure you have the monitor cables correct. Try another monitor hopefully works so you can go into your device manager and make sure the right drivers are loaded and that your monitor is listed. You may do some research because I'm not sure but I think your monitor uses a back light & an inverter which is replaceable and not usually a difficult job or to expensive. Labor of coarse cost more than the parts. Monitors use a video card or on board video so make sure these are not the problem.
Are you sure its not in wake mode in the bios?
If you shine a light on the monitor when the comp. is on and the monitor light is on you may be able to see your screen. That would be the back light.
When if all and what was going on when it stopped working?
Jul 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
KDS K717s 17" LCD Monitor Logo
712 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
