My tx1499us has a blank screen on boot up. It does not show anything during or after boot up. Is there anything I can do or should I just take it in for repair?
Does the hard disk spin up and the hard disk LED light flash? Does it appears to boot up but you get a blank screen? If so if you look at the screen at a sharp angle do you see a dim image?
If you have a fn key and an outline of a monitor on another key, hold down the fn and then hit the other key, a couple times if need be. It should toggle between an external monitor and the laptop.
If that doesn't do it, try attaching an external monitor, re-booting and seeing if it comes up on the external. Then try toggling again.
If it doesn't work, it's probably time for repair.
I would try reseating the memory(located on the bottom) of the computer. Also check to see if any lights come on at all or fans as that can determine the nature of the problem. But yes this is a serious problem(most likely hardware related) and if your not comfortable with taking it apart I suggest taking it to a shop. Just make sure if they say they need to replace the part ask for the old part back.
Was this helpful?
Yes
No
Popular Solutions for HP HP Pavilion TX1000Z 12.1"
HP HP Pavilion TX1000Z 12.1" Touch Screen TABLET NOTEBOOK...
hi.my quicktouch don't work.i try to turn the volume or something,but nothing happen. i think the...
(More)
hi.my quicktouch don't work.i try to turn the volume or something,but nothing happen. i think the touch tuned off. can you help me?
i had a problem with the volume control going crazy... my friend disabled them but now my mute goes...
(More)
i had a problem with the volume control going crazy... my friend disabled them but now my mute goes crazy! this is driving me to dispair... anyone know how to fix this?
Hi I and a work colleage have had the same Pavillion TX 1000 problem, laptop has been rebooted 4x in...
(More)
Hi I and a work colleage have had the same Pavillion TX 1000 problem, laptop has been rebooted 4x in 12 months from restore disk, wirless drivers dissapeared, White screen 3/4 x now will not boot up?? lights come on round side of lap top but nothing else. I have been in contact with HP the only way to make a difference is to call this number with serial number and product code- 02076600906 (number didnt work 1st time but keep trying) Explain what has happend and if enough of us do this then maybe HP will admit there is a manufacturing problem and recall and repair the lap tops for free- HP quoted me £256.00 to repair this lap top out of Warrenty. They have already recalled some pavillion laptops but are yet to recognise the problem with the TX1000. Good luck let me know how you get on. SM
