Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore Elite Dishwasher Problem
My Kenmore elite diswasher of 5 years seems to be dead. no light, nothing starts. power to unit is good. is there a relay or fuse to check in the door panel
  • 4 more comments
  • annasearcy Oct 09, 2008
    same problem but model 665-17579202 will this part work on mine as well
  • castaways_li Mar 14, 2009
    Brand new dishwasher, installed today in the caribbean and the power is good to the machine but board does not light up, nothing happens!
  • Anonymous Mar 28, 2014
    need wiring diagram and fuse location
  • Anonymous Mar 30, 2014
    Kenmore elite diswasher model 665.1392, 665.1394 complete light blinking nothing else works
  • Anonymous Mar 31, 2014
    during install, unable to open door on unit, no reference in manuals, how does this work?
    having difficulty opening door, is it manual or electronic?
  • 5,911 Answers
The dishwasher should have a thermal fuse mounted to the control board behind the operator consoleKenmore Elite Dishwasher Problem - 4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at Order on line and have the part shipped directly to you. access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Kenmore elite dryer no pwer
If the dryer does nothing at all, it's probably the door switch. Give it a good look over.You Does the light com on inside when you open the door? Does it appear to have power but just won't start?
Jul 24, 2009 | Dryers
Just dead. Doesn't light up or start or respond.
You will need to replace the power supply most likely. If you can find a fuse or relay, check with an ohmmeter to determine that they are good. You can use a voltmeter to determine that there is power going to the control panel.
Jul 13, 2009 | Washing Machines
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore HE 5 electric dryer, no power
With the dryer unplugged, remove the lower panel under the door. To remove, you will need to loosen the screws under the bottom fronyt edge. With the screws removed, the panel drops down a little, then comes off. Check the Thermal Fuse located on the blower fan housing directly under the drum. This is a white or gray plastic component with 2 wires. Take a resistance reading across the fuse. You should get a reading of 0 ohms (or very low resistance). If the fuse is bad, your problem may be solved. A blown thermal fuse will kill the entire dryer. In addition, if the thermal fuse is bad, it usually blows for a reason. Make sure your dryer ventilation is clean and clog free. A dryer that is clogged will overheat to the point fo failure which causes internal component failure. Not to mention, this is a fire hazard. Please check and let me know. If the fuse is still good, the problem may be with your main control board. The fuse is the more common and least expensive option to try first. I hope this helps you. Let me know what you find...
May 29, 2009 | Kenmore Elite 45986 Front Load Washer
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 | Dishwashers
Completely dead
circuit breaker tripped, fuse blown in dryer.........
Apr 05, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
1,823 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
