Question about Tivo DirectTV Remote Remote Control
Loss of certain channels
We have direct tv and tivo. We can get CNN on the other sets in the house but not on the set that has the tivo. Have tried all the usual remedies like restarting and uplugging.
  • 752 Answers
Go into Messages & settings > Settings > Channels > Channel Line up and make sure there is a checkmark next to any channels you want and uncheck those you don't.
Posted on Jan 19, 2008
How do I set up a tivo series2 to a new digital tv. Do I need analog to digital converter?
Analog to digital converter is for OTA transmission. You are using a cable system, right? If so you have to feed into your Tivo the cable output signal from your cable box and set your tivo to correct rf or video input. Since cable tuner is determining channel all you can do to record is set the channel on your cable unit and program your tivo to turn on and record the input at appropriate time..
Aug 28, 2017 | Tivo Televison & Video
No video from an Apex digital converter box to TIVO
You may have to set the channel 3/4 switch on the lower right rear of your TiVo to match the output setting of your Apex converter. If your Apex converter is equipped for L/R audio and video output you will get better results using a three-conductor cable to connect to your TiVo.
Dec 08, 2013 | Toshiba DVD Recorder AND Series2 TiVo...
Comcast cable channel one off from Tivo channel
I've never, ever heard of this problem - having been a happy TiVo user for over 15 years. The very first thing I would do is call Comcast and tell them what is occurring. How long had everything worked OK before this happened? If things were OK for a long time before this, and if your TV carrier was, likewise, Comcast for a long time; and if you haven't gotten a new TV or cable box for a long time, then the problem must rest with Comcast. It must!
In our home, with the number of movies, shows/sporting events/etc. which we record, that would be totally unacceptable!
Try this: Unplug everything (with everything turned off). Make sure your TiVo remote is good (fully charged batteries and the code is right for your TV/cable box), Wait for 10 minutes and plug everything back in, starting with TiVo, then the TV, then any other accessories.
Plug back in and do a complete restart from scratch - like you did when you first set up TiVo.
Make SURE that your receiving channel (3 or 4) is the same on both. It could be that someone accidentally has changed it - are there kids in the house?
If none of this works, get Comcast in there. That's all I can tell you. . .
JB
Apr 11, 2017 | Tivo Televison & Video
Changing Channels with Series 2 Tivo
Make sure you are using the IR cable to control the Cable Box.
Make sure that you have already done a guided setup again from the tivo box.
Jan 04, 2010 | Tivo Series 2 80-Hours Video Recorder
When my Tivo stops recording a show on, say, channel 54, instead of staying on channel 54 it switches to channel 5. In other words, it only gets ''part'' pf the channel number. This happens with other...
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
Sep 12, 2009 | Tivo Series2 TCD649080 Video Recorder
I have upgraded my comcast service to an extended version including more channels but no cable box. I've been unable to set up my TIVO dual Series device to get the new channels, it only recognizes the...
Try this first...Press the TiVo button at the top center of the Remote, then > Messages & Settings > Restart or Reset System > Repeat Guided Setup and then follow the onscreen instructions from there.
This should load your new channel lineup into your TiVo.
If all the channels are still not recognized... Press the TiVo button at the top center of the remote, then > Messages & Settings > Settings > Channels > Channel List and then make sure all of the channels you receive are checked.
Jun 08, 2009 | Tivo Series2 Dual Tuner Digital Video...
Hughes sd-dvr80 direct tv receiver tivo
go to your settings page and run the initial setup. make sure each section is done correctly. the tivo might take a second to start downloading the locals.
Jan 03, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo DirectTV Remote Remote Control Logo
48 people viewed this question
Top Tivo Televison & Video Experts
Dave
Dave
Level 1 Expert
Tom Chichester
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
