Kenmore AC2044-1 Air Purifier
Problem for Kenmore AC2044-1 Air Purifier
Kenmore Ac2044-1 electrostatic air cleaner...cleaned
By ofbartons on Sep 23, 2009
Kenmore Ac2044-1 electrostatic air cleaner...cleaned the two filters and replaced but works 20 minutes and stops....clean cell light blinks....sent to Sears repair....returned....cannot get parts....? Is it the circuitboard? Is the cell still dirty? Can I use a particular cleaning product or chemical to get it cleaner?
Comments:
Sep 25, 2009
- This solution is not my problem.......I have cleaned the metal cell box repeatedly....and installed it in proper position......runs 20-30 minutes and stops with blinking "clean cell" light....? Please advise asap with other options...?
Solution #1
posted on Sep 23, 2009
Not Rated)
jyackle5
Rank: Guru  Kenmore Expert
Rating: 90%, 1316 votes
Take a flash light to the filters to see if there is any debris. This helped me because as I was examining the cell for debris I noticed markings for "Top" and "Bottom" inscribed on the four corners of the front of the cell that I had never noticed before. After cleaning I had installed the cell upside down. It would work for 20 minutes and then shut off. The rounded thingies on the bottom of the cell are contacts which should touch the little springies on the bottom of the housing.
Solution #2
posted on Sep 25, 2009
Not Rated)
ginko
Rating: 89%, 5272 votes
If the two filters have already been cleaned, and maintenance had recently been done by sears, then it is likely the control board.
The problem is that Sears does not distribute replacement parts for this particular appliance model. Therefore repair must be done at sears.
Popular Solutions for Kenmore AC2044-1 Air Purifier
Questions and Unsolved Problems for Kenmore AC2044-1 Air Purifier
Do you recommend Kenmore AC2044-1 Air Purifier?
Answer
Answer
Where can I get the wiring diagram for the EWM-300?
Answer
hOW DO YOU CLEAN FILTER?
Answer
My ionic breeze g.p. has a burned out bulb, and no power lights come on. Is this because of the bulb... (More)
Answer
My Amcor Group Air Treatment System 120 needs new filters, how can I obtain them
Answer
i have a ionic breeze that i bought two for one at bed bath and beyond. the switch does not turn it... (More)
Describe your Air Purifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifier Experts
Top Air Conditioner Repairmen
in Newport, KY
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
