Question about Canon Rebel XT / EOS 350D Digital Camera
Canon rebel won't power up
Any suggestions?
  • JulesR Dec 24, 2007
    Wont turn on. Was working great on minute - nothing the next. Any ideas?
  • RickeyAnn Jan 18, 2008
    My Rebel XT all of a sudden died. I will not power up. I charged the battery and reinserted into camera and it still will not come on. HELP!!!
    Problem Solver:
  • 11 Answers
If you have only one battery (or only one device to test the battery with), it is hard to determine if the issue is the battery or the camera itself.
If possible, I would recommend trying a second battery if you have not yet done so. Maybe a local camera store might have a display they could possibly allow you to try at the counter.
If the problem has persists with multiple batteries, unfortunately it sounds like the camera needs to be serviced.
Posted on Jan 29, 2008
I have a Canon eos Rebel XT. Once powered on it will take photos for a short time, get hot and power off by itself and won't power back on till it cools off. Additionally once powered on even when
Remove back cover and check for missing screw - especially check if it is touching the orange wire that powers the back light for the rear LCD that s part f the rear cover. Screw that is loose is almost always the bottom right screw that holds on rear circuit board. If it is not there and you see the empty hole, it could be anywhere in the camera, so you will have to keep on disassembling until you find it.
Jan 15, 2013 | Canon Rebel XT / EOS 350D Digital Camera
How do you adjust internal mirror in Canon EOS Rebel XSi Digital Camera?
The mirror won't affect the picture, since it flips out of the way when you take the shot. It's much more likely that the lens mount has loosened or been knocked out of alignment. Unless you have access to a precision optical bench and other tools, I'd suggest taking it into a reputable camera repair shop to have a trained professional do the job.
Oct 24, 2011 | Canon EOS Rebel XSi Digital Camera
I need a handbook for a canon D300 rebel
We suggest visit this link for Canon EOS DIGITAL REBEL/EOS 300D DIGITAL Operational Guide.
Hope helps.
Oct 14, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Camera still dead with a new charged battery. Is it possible to overcharge a battery so it won't work?
If you have another battery definitely give it a try, most likely it won't work either. The problem is probably the fuse located on the DC/DC board that has 'blown' causing there to be no power. Replace the board and the camera should work fine. Canon will probably charge $175 or so for the repair.
Hope this helps.
Thomas
Sep 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Dec 19, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My 9 month old camera will power up, focus and flash however it will not take the picture. When looking through the view finder, "busy" flashes when trying to take the picture. The battery is fully charged...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jul 31, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
