Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Problem for Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
No power to dishwasher
By mcerda07 on Sep 23, 2009
no power to dishwasher and checked power breaker already it seams to be ok. I think its the door switch. I closed the door to hard one day so I wonder if it did something to it.
Best Solution
posted on Oct 11, 2009
Very Helpful)
charlymonty
Rank: Wiz
Rating: 82%, 247 votes
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
thanks.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Sep 23, 2009
Not Rated)
nu267
Rank: Guru
Rating: 91%, 44 votes
could be the door latch, but before you replace thast you may want to remove access panel at bottom and make sure you have power their . you would need a volt meter to check for 120v.if you have 110v then could be latch or board if this unit is digital.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Gold 24 in. Built-In
Questions and Unsolved Problems for Whirlpool Gold 24 in. Built-In
Do you recommend Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher?
Answer
Answer
Our Whirlpool dishwasher won't respond? The Green Light is flashing but we can't get the machine to... (More)
Answer
no display Dishwasher will not start. Have checked fuse box circuit good.
Answer
A loud humming/grinding noise and it is not the pump. Any ideas?
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , MD
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
