Question about Mitsubishi WS-55905 55" Rear Projection Television
No red or green (only blue, yellow) in picture
Picture was fine one day.
Turned on next day, and no red in picture.
Only blues and yellows. No green either. Red shows as muddy brown. Green shows as brown.
Manual says, "lamp out button should be red"... no button visible, is red.
  • 6 more comments
  • odonsarge Dec 16, 2007
    Mitsubishi WS-55413
    55"
    rear-projection
    Purchased 11-03.
    Never moved.
    Switched from cable to dish 2 months ago.
    Absolutely no problems, in any respect, until this problem with color.
    Any ideas?
  • Anonymous Jan 15, 2008
    no red or green
  • Anonymous Apr 01, 2008
    TV only has blue and yellow - no red or green. Everything looks muddy brown that should be red & green. When we leave it off for awhile and then come back and turn it on - the reds and greens return.
  • tdcutts Dec 30, 2008
    no reds in picture - changing the tint and color has no effect. Plenty of blues/ yellows. TV was moved but color was fine when initially set up after the move. Not sure what's happened. Its a JVC as noted.
  • MichelesKid Apr 09, 2009
    I moved and had my cable transfered. After the cable guy set everything up again, I noticed (later on)that there were hardly any colors other than blue and yellow and people had green tint at first. Now everything is blue and yellow. Have had no luck with adjusting tv settings or setting the tv back to factory settings. Neither option has produced any results
  • cappuccinoma May 11, 2010
    could anyone tell me which is or where is the signal board on a 55in Mit ws-55905. This sounds like my problem also. Thanks
  • Anonymous Mar 20, 2014
    sometimes after 45 minutes with sound and no picture you can turn the TV off and back on the has a picture and sometimes the picture is green, blue or red. turn the TV off again and back on the picture is fine until the next day. Then the process starts all over again when you turn on The TV.
  • Anonymous Mar 22, 2014
    I have no green or red tint
    President:
  • 4,402 Answers
Need make and model
Posted on Dec 15, 2007
  • Cary Farah
    Cary Farah Dec 17, 2007
    sounds like the you need to replace the signal board, more troubleshooting would be needed to confirm.
Your TV has red, green, and blue lamps in each pixel. The same signal is going to your red and green lamps, so you always get the combination which is yellow. Must be a problem with a wayward contact like solder spread too far. If you can locate where the input signal is sent to the lamps you may fix this.
Posted on Dec 15, 2010
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
What does the stereo colors stand for on an 1992 crown victoria Red, black, Grey/blue, yellow/black, white/purple, green/black ,blue/red, orange/green, white/green, blue/white, brown/yellow,...
Red = ground
black = ground
Grey/blue = Left rear (+)
yellow/black = ignition 12v
white/purple = right rear (-)
green/black = (could this be green / violet?) than it is 12v constant
blue/red = illumination
orange/green = left front (+)
white/green = right front (-)
blue/white = left front (-)
brown/yellow = left rear (tan / yellow) (-)
green/orange = right front (+)
orange/red = right rear (+)
blue = not used
Nov 10, 2010 | Ford Car Audio & Video
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
From cable box component out to tv component picture is on no aud
You need to also connect the RCA audio out (red/white) from your source to the audio input on the TV. You do not need the yellow wire as that is for composite video. The component cable (red/green/blue) is only for video. Look at the input on the TV where you connected the red/green/blue cable. Right next to it, you should have another red and white connectors for the audio input. Connect that to the audio out on the cable box.
May 01, 2009 | Digimate DGL20 Television
1994 mercedes 500sl dash cluster problem
Hello, I don't have a picture but maybe this will help,
red/yellow-4
brown/white-1
brown-2
blk/yel-2
pink-11
green/white-13
green-12
brown/red-18
brown(small)-17
blue/brown-10
blue/green-7
blue/white-14
3 5 6 8 9 not used
I hope this will help.
CYA Gator241
Dec 08, 2008 | 1994 Mercedes-Benz Mercedes Benz Sl Class
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Mitsubishi WS-55905 55" Rear Projection Television Logo
1,497 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
