Question about Linksys Wireless-G WRT54G Router
Not able to get on internet wired
I purchased a linksys wrt54g I managed to get on wirelesss with my laptop but my desk top with the cable hookup (host) is not able to get on to the internet
Hhhhhhhheeeeeeeeeelllllllllllp
Posted on May 01, 2008
  • 556 Answers
When you say you can get on wireless with your laptop does that mean---
You can connect to the router or
You can connect to the internet and get web pages such as google or fixya?
If you can get to google and fixya then the issue is not the router setup to the internet. Otherwise let me know you need help setting up router access to the internet. There will be more questions before I can give you directions to complete that.
When you say cable hookup for the laptop do you mean an ethernet cable to the router? (these cables have wider connectors that the phone wires and connectors -- used for phones and modems) If not what kind of cabling to where? (some installations permit connection via either one ethernet port OR one USB port to their equipment. -- note the OR if you have the router attached to the ethernet port you may be required to move the desktop from the USB port to the router using an ethernet connection (network adapter and cable). This might require the purchase of additional hardware (a network adapter for the PC and an ethernet cable -- if you provide the manufacturer and model of the desktop it will probably be possible to determine if your desktop has a network adapter already)
If you are using an ethernet cable to the router the following are probably items to check.
Can you swap ethernet cables (with a spare) to assure it is not the cable?
Can you hook your laptop or another computer (maybe a friend's) to the existing cable to assure it is good? (you will need to turn off wireless on the laptop to use it, if you know how)
Try switching ports the cable is plugged into on the router to see if that changes anything? (try the same with a known working machine possibly from a friend)
If there appears to be a cable issue perhaps you could test it on a firend's machine and his network to be sure.
Verify the proper installation of the network adapter in the desktop computer.
By testing it on a friends network, if possible?
Depending on what you find there could be additional questions and instructions to purchase additional items, setup drivers for you existing equipment, or a number of other things. Primarily this first set of questions is to attempt to isolate the problem and focus on the solution applicable to your specific situation.
Posted on Dec 15, 2007
I have a linksys wireless-g wrt54g v8 router but do not have the installation cd. I have a desk top pc w/ a dsl modem and want to install the router so I can use a laptop in other parts of the house. Do...
Hi leftella, First of all, I would like to ask you few questions. 1.Who is your ISP(Internet service provider) like verizon, Bell, Comcast? 2.How many ports you see at the back of the Modem?like WAN, Ethernet, LAN, DSL, Data? 3.How many ports you see at the back of the Router?like Internet,Ethernet,WAN, LAN? 4.What is the make and model of the laptop with which you want to go wireless?
To setup the router you don't need any CD, just need to connect the Modem to router and router to your computer with hard wire Initially and then after setup, you can go wireless.
Sep 15, 2011 | Linksys Wireless-G WRT54G Router
Trying to run setup wizard on my WRT54G-TM,so i can block other people from borrowing my internet.I have one desk top hooked up and two laptops, works great ,but when i run the wizard disk it tells me...
To test your Internet connection, connect a LAN cable from your computer to the DSL or cable modem and if you can browser the Internet then your Internet connection is OK, then the problem is the LAN cnnection to the Linksys or the Linksys may not configured correctly.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Linksys WRT54G-TM Wireless Router
Just moved to Canada and hooked my desk top up. i have internet through cable not phone line. i have internet with a cable from linksys to desk top but i have no wireless to laptops. i think i need to...
You need to configure the Linksys with the wireless settings, ie. the SSID and encryption. then you need to configure the wireless card in laptop with these router's wireless settings so it can connect with the wireless router.
Open a browser on your computer and type in the Linksys configuration URL.
http://192.168.1.1
The default PW = admin
then go to the wireless section and configure the SSID and encryption. I suggest you use WPA or WPA2 these are much stronger encryption than the older WEP encrtption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Let me know if you need more assistance.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Can't connect acer aspire on to linksys wireless.
Is the acer wired to the router? call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Feb 19, 2009 | Linksys Wireless-G WRT54G Router
Do not know my password for wrt54g want to use Ibook
the default login for linksys is user name: (leave blank) ,password: admin; if that doesn't solve your problem unplug all the cords and hold the reset button on the back of the unit for 30 seconds then gradually reintroduce it to your network.
Jan 13, 2009 | Linksys Wireless-G WRT54G Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Printer connection to the Linksys Wireless-G WRT54G
You bought a router for your printer? Or you have other computers you need to connect to the internet.
If you have more than one computer than you hookup (or connect wirelessly) your computers and then network yor printer so that document can be printed from any machine on your network. If this is not what you are looking for feel free to fill me in on more infomation.
http://compnetworking.about.com/od/homenetworking/a/routernetworks.htm
Try this link for help with networking your printer.
Oct 29, 2008 | Linksys Wireless-G WRT54G Router
I need a pass pahase
you can check the the passphrase on the setup page of the your router. does you laptop connects to the router via an ethernet cable.
reply to this post so I can give the steps on how to check it.
Jun 05, 2008 | Linksys Wireless-G WRT54G Router
Need to know how to wire from desk top for lap top, I have router #wrt54g
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3988&lid=7553637401B09
HI
Use this link to get the required information
thank you.
Apr 30, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
97 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
