Question about Sony ICF-CD555TV 7 in. Portable Television
PAUSA tv problem standy by is on.
Iam repairing pausa tv , before had a problem of storing channels, now after power failure , when power cames back the system power supply were dead, i already fix that and now i have power on standby but i cant power the tv on.
i need help! please may some one help me through this on the power control i do have this ic no M490BB1
There should be +5 volt ,but yet no power on,check h out transistor for short
Posted on Oct 22, 2008
Blinking standy light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Sony Bravia KDL-32BX320
Como quitar una pausa a una minolta 350
Check that you are connected to the printer in your devices and printer settings on your P.C
Aug 26, 2014 | Konica Minolta bizhub Office Equipment &...
Tv green light flashes
cuando le dan a prender prende el led verde y la tv prende prende por 3 segundo presenta en la pantalla el letrero sony y se apaga la tv y el led verde. luego prende el led rojo 2 parpapadeo pausa larga 2 parpadeo y pausa larga y se repite
Dec 08, 2013 | Sony BRAVIA KDL-40V3000 Television
No funciona pausa play rew stop ff
Hi Marco, I am from Spain, I tried to write in Spanish but the system does not allow that.
I have the same problem. Have you the solution? I saw nobody answered you in two years.
regards from Alicante.
Alex
Aug 02, 2013 | Sony Handycam CCD-TRV37 Camcorder
How to unlock LG DV 642 DVD region code??
Para Convertir el DV642 de LG a multiregion:
1- Enciende el DVD
2- Abre la bandeja de el DVD
3- Presiona el boton "0 (Cero)" 3 veces dejando entre cada vez que presiones el cero 1 segundo de por medio asi 0-0-0 donde el "-"es un espacio de 1 segundo despues preciona el boton 0 para fijar la region a cero para ponerlo en multiregion
y presiona pausa para guardar.
Apr 07, 2012 | Televison & Video
El display se ve de cabeza
pointer 6920: Debes de cargarle el ultimo firmware disponible, este firmware trae resuelto el problema del display. Posiblemente tengas que cargar tambien el Boot Loader para que la impresora acepte el firmware. Puedes descargar ambos archivos desde ftp://ftp.datamax-oneil.com/Printer%20Firmware/ , para cargar el boot loader debes de poner la impresora en modo descarga presionando las teclas PAUSA y TEST mientras enciendes la impresora.
Roberto Martinez
padrino99@prodigy.net.mx
Mar 31, 2011 | Datamax I-4208 Thermal Label Printer
How can i change my region code for my LG HT353SD dvd player
pulsar tecla pausa despues 1,4 ,7,2 y aparecen los datos de la memoria , se cambia el dato 42 por 02 y posteriormente se apaga el equipo y listo ya esta en region 0
Aug 18, 2010 | Computers & Internet
Quisiera saber si hay que cambiar tarjeta
Checkas aqui... http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WTW6600&siteCd=WHRCOM porque hay informacion en espanol en los instruciones por tu lavadora.. los instruciones dice: Oprima Pausa/Anulación (PAUSE CANCEL) una vez para despejar el código. Presione Inicio (START). Si el código aparece nuevamente, llame al servicio técnico.
Jun 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Escuchar mp3
Go to www.sandisk.com and download the operating instructions.
Jan 15, 2008 | SanDisk SDMX1 MP3 Player
Sony ICF-CD555TV 7 in. Portable Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
