Question about SanDisk Sansa e250 MP3 Player
Sansa e250 I've got an expansion SD card in mine, but everytime you switch it on it shows "rebuilding database" and takes forever to properly switch on and play. This is really frustrating. Any ideas?
  • cmcew01 Dec 16, 2007
    Tried that!
    President:
  • 1,944 Answers
Using an external card reader, back up the data on the card and then reformat the card. Then put the card back into the player. Hopefully this should solve your problem.
Posted on Dec 15, 2007
  • Damen Wong
    Damen Wong Dec 16, 2007
    * Try reseting the database without formatting
    If you have problems with the database (like ghost files) there is no need to format the whole player. Switch the player in MSC-mode (Settings->USB Mode) and connect it to your pc. If you haven't already done so, activate hidden files. Now go to your Sansa. You should see some new folders there after you activated the hidden files. Go to System\Data\ and delete the Pp5000.dat. After you unplugged the player it should rebuild the complete database.
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
The micro sd card dose not work or even show up on the comp screen
Make sure the usb mode is msc this allows you to see the expansion card on the computerthe 200 series only takes 2 gig minicard
usb mode is in the settings of your sansa
Apr 06, 2010 | SanDisk Sansa e250 MP3 Player
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
Mar 16, 2010 | SanDisk Sansa e250 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Media Player
Try to reformat the card. Go to My Computer then right click the drive corresponding to your sd card and select format. Put some music back on, and try again. When your Sansa boots you should get a message stating it's refreshing the database. Good luck.
Jan 06, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Refreshing database - Everytime
there nothing wrong its jsut the way the mp3 player refreshes the play lists mine does it too
Feb 06, 2007 | SanDisk Sansa e260 MP3 Player
How do you refresh database?
This just means that the player is refreshing the songs on the list, it does not mean that you have to do anything.
Feb 02, 2007 | SanDisk Sansa e250 MP3 Player
Expansion slot for sansa
It should work if it was made by Sandisk and if it is a Micro SD memory card.
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
