Question about Dell E171FP 17" Flat Panel LCD Monitor
Dell e171fp + turn off after a second
Recently purchased a second hand lcd monitor, it turns on and the display is fine but the screen goes black after a second or two.
Any suggestions? I've checked connections and they seem fine inside the unit.
Cheers.
  • 2 more comments
  • cnatt Dec 16, 2007
    thanks for the help, well when it turns on i can see the lcd menu for a second then it goes off and all i'm left with is a blank screen. The green power light remains on though?
    any ideas?
    hi thanks for your help. I can see the lcd menu for around a second then it goes black. The green power light remains on though?
    Any ideas?
  • pjhorton21 Dec 02, 2008
    I also have a Dell LCD monitor - on for 1 second, than off. Cannot bring up the LCD menu for more than a second (and then only when the computer first turns on). The last thing i did before this started to happen was to increase the brightness on the LCD monitor.
  • carnilio Jan 26, 2009
    I have, and also have had this problem too. Apoparently there is a weakness in theese models whne they get older where you cannot increase brightness or certain colors or tyhe screen will auto-dim itself. I had ofund a fix that describerd what buttons to pres to navigate the menu, without seeing the screen, to reset the screen to factory settings, wich restored the image. But i just cannot seem to find it again, to "fix" the screen this time. going ot keep searching tohugh and post it here if I find it.
    Champion:
  • 238 Answers
Check for power management settings in the LCD menu, or does it switch off while u r in the menu.. what does the power LED indicate after switching off, also sometimes display cards do act funny.. check it out an d let me know
Posted on Dec 15, 2007
Hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dell E171FP - goes blank after a second or two LCD monitor powers up for a second or two and then goes blank but the power light remains on. Display is fine for the few seconds it remains on. ...
You need to look for bad solder joints, bad caps, shorted transistors, etc,
See example here: http://s807.photobucket.com/albums/yy352/budm/DELL/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Apr 24, 2011 | Dell E171FP 17" Flat Panel LCD Monitor
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
My dell computer screen goes black after a while after windows xp second up grade went on. what should i do without taking upgradee off or changing screens?
Right click on your desktop go down list to properties and left click under the screensaver tab click the power tab and turn off the power saver in other words change settings to always on and no hibernation
Nov 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Padlock appears on screen
The padlock is an indication that the On Screen Display is locked. You can also lock or unlock the OSD by pushing the Menu button for over 15 seconds.
http://support.dell.com/support/edocs/monitors/e171fp/en/controls.htm
Sep 30, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Laptop LCD goes black after a few seconds
Yes, The pink tint is an indication that the backlight is failing. Now the backlight is basically dead, the best way to get back going is to do an Ebay search for your model laptop and get a new screen. Most screens can be purchased for around $50.00 - $70.00 and they are very easy to swap. Email me if you need more info.
Buddy
Corporate Computer
www.ccl-la.com
Aug 03, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FP 17" Flat Panel LCD Monitor Logo
463 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
