Question about Canon MultiPASS F60 All-In-One InkJet Printer
MY Canon Pixma MP 500 Printer won't Print.
Dear Sir/Ma'am :
The Yellow Ink Tank ran out of ink. I replaced it as usual with the proper Ink Tank. But this time in the display window it stated a code error which reads: 6A00 ERROR code. And also, the alarm light which is yellow is blinking. I don't know what is wrong!
I've had the printer since about 2005.
Please if you have any suggestions...I would greatly appreciate it.
Thanks,
Beep433@Yahoo.com
  • Anonymous Mar 03, 2008
    hello....i have the exact same error code 6AOO........what did you do and how can i fix it??........njdave35@yahoo.com.....thanks
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
SOURCE: MY Canon Pixma MP 500 Printer won't Print.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  5. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  6. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
  7. clear any paper jam
  8. May be your product requires repair service.
Posted on Apr 03, 2008
tsaros90
  • 10 Answers
SOURCE: My Printer says error code 6A00 What do i do?
Try this especially if the printer had not been used for some time.
Switch it off, open the lid and manually (GENTLY!)slide the cartridge-tray to the left. Then you can see if a piece of paper or ink stucks it. Gently degunk the base pad with a little isopropyl alcohol on a Q-tip and ease the mechanism back.
Posted on Dec 01, 2008
  • 117 Answers
SOURCE: I have a 2006 PIXMA MP 830. It worked beautifully
your printer the error Purge unit problem
Posted on Oct 07, 2009
bschilz
  • 2049 Answers
SOURCE: I have a error code
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Posted on Oct 16, 2009
pineworks
  • 4041 Answers
SOURCE: alarm button flashes, check printer, press OK
Solution 1:
Solution 2:
Solution 3:
Posted on Jan 25, 2010
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Sir , my printer canon pixma ip 1200 when i start to print it show waste ink obsorber is full. please help
    Hi. I think the problem on that one is the waste ink tank is already full, so you need to clean it or replace the pads on it, because when you are printing or opening your printer it blows little amount of ink to the heads so that it will not be clogged, and that ink goes into the used/waste ink tank. Also after cleaning the used/waste ink tank you need to reset the counter of the printer so that it would print again, you can just download the counter reset software2_bing.gif over the internet or just bring that machine to an authorize canon printer technician. Hope this Helps
    Jun 09, 2010 | Canon PIXMA iP1200 Photo Printer
    Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
    Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
    Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Printing only b&w from a colour Canon Pixma 500
    The Canon will not allow you to print with empty color tanks, or without them installed.Canon does not want the ink to dry in the printhead which would destroy he printhead.
    Sep 01, 2009 | Canon Pixma MP500 All-In-One InkJet...
    My printer won't print yellow even when I replace the cartridge.
    Desperate measures!
    I have a PIXMA MP 750 and months ago my yellow ink stopped printing. I was only able to use the printer for black and white printing. Every once in awhile I would try multiple deep cleans, new ink cartridges, etc. etc. I talked to the very unhelpful folks at Canon who suggested a new print head ($70), but they couldn't guarantee this would actually work. They really thought it would be best just to buy a new printer.
    Although I was feeling bad about adding yet another cheap printer to the landfill I'd pretty much decided to get a new printer. As a last resort I decided to use a suggestion I came across (at pcuser.com) to run hot water through the print head. It was easy to remove the print head (check your manual). I propped the head up in my dish drainer and ran hot water straight from the tap first through the end with the little circular parts and then through the end with the metal strips. I eventually used boiling water from the kettle.
    As I poured water through one end I started to see yellow ink coming though the other end so I figured the ink had dried in the head. I kept pouring water through (from both ends) until the water ran clear. I dried the print head, put it back in with the cartridges and VOILA! after MONTHS without yellow ink it's working beautifully again!
    If you've tried everything else and feel desperate enough to buy a new printer you might want to try this and report back.
    Jan 16, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
    Mar 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
    Pixma mp500
    • Replace a new Canon ink cartridge as it could be due to the unique features that Canon has build on their ink cartridge not done properly which resulted to be faulty. Report the issue to Canon if your existing ink cartridge is not from other 3rd party band, Canon should be able to do 1 to 1 exchange once confirmed that it is their ink cartridge problem. Cannon has build the unique feature to prevent users from misusing 3rd party ink cartridge on their printer.
    • Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
    • Or missing pin has dropped off from the print-head which causes the printer not able to read the ink cartridge, printer needs to be serviced.
    • (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
    Nov 25, 2007 | Canon Pixma MP500 All-In-One InkJet...
    Canon MultiPASS F60 All-In-One InkJet Printer Logo
    117 people viewed this question
    old marine
    old marine
