Home | Makita | 6349DWDE 18V 1/2" MXT Driver - Drill Kit | Makita 6349DWDE 18V Cor...
Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit
Problem for Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit
Makita 6349DWDE 18V Cordless Clutch
By wildcatmahon on Sep 23, 2009
Same problem here the clutch started to slip awhile ago and now at the present time it will only torque under low speed in drill AND drive mode. Brushes are good and well above the limit mark. Wondering what the possible problem and scenarios are so I can try to fix it. Thanks in advance.
Best Solution
posted on Sep 26, 2009
Helpful)
rowdy45176
Rank: Guru  Tools - Building & Power  Expert
Rating: 91%, 540 votes
could be the clutch needs replaced, but I would check to make sure the high/low switch is fully engaged. Inside the clutch there is ring gear that could have the teeth rounded off I would go to Makitatools.com and type in your model number for a breakdown so you can see what you are getting into, they are not that hard if you are mechanically inclined and just watch how you do it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Makita 6349DWDE 18V 1/2" MXT
Questions and Unsolved Problems for Makita 6349DWDE 18V 1/2" MXT
Do you recommend Makita 6349DWDE 18V 1/2" MXT Driver - Drill Kit?
Answer
Answer
I need to look at a manual for Makita HR2510 Rotory hammer I think I need to add oil but Im not sure... (More)
Answer
need a replacement rechargeable battery for MAsrecraft 54-2848-4 cordless drill
Answer
I have a bosch psr18li-2 drill and i can not remove the battery is it a problem with this modle.... (More)
Answer
Hilti TE6A battery dril 36volts, had the battery re celled, but the trigger is intermitant put new... (More)
Answer
my 19.5 sears drill chuck wont turn, it sounds like gears or something not connecting, maybe a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Makita 6349DWDE 18V 1/2" MXT...:
Top Drills / Driver Experts
Rank: Wiz Wiz
Solutions: 897
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
