LG LFX25960ST Stainless Steel French Door Refrigerator
Problem for LG LFX25960ST Stainless Steel French Door Refrigerator
Have a lg lfx25960st has frost on back wall of
By denisemhoppe on Sep 23, 2009
have a lg lfx25960st has frost on back wall of freezer fan was making grinding noise now no noise and wont freeze ice thanks d hopper
Solution #1
posted on Sep 23, 2009
Not Rated)
mrwiebe28
Rank: Master
Rating: 99%, 7 votes
Older freezers have a mechanical timer that shuts the cooling unit off and activates a heating element to melt the ice that forms on the cooling coils next to the fan. Newer ones control it with a circuit board. It sounds like yours is not defrosting and the ice buildup has stopped the fan. Or the fan could be bad and without the airflow thru the cooling coils they are covered with ice.
You need to remove a cover inside the unit to get to the fan, cooling coils, and defroster heating element. There could also be a thermostat attached to the heating element that will need to be checked.
Unplug the unit, disconnect the heating element and check for continuity ( with an ohms tester ) , it should give some reading on the tester. You will need to talk to a repair shop to get the exact ohms it should read. If you have a friendly repair person, they will tell you how to check everything out.
Was this helpful?
Yes
No
Popular Solutions for LG LFX25960ST Stainless Steel
Questions and Unsolved Problems for LG LFX25960ST Stainless Steel
Do you recommend LG LFX25960ST Stainless Steel French Door Refrigerator?
Answer
Answer
I have the model with water only in door and icemaker. Neither are working. Water is hooked up and... (More)
Answer
we set the fridge to 37 and the freezer to 0. this seems to be too cols. what is the highest temp... (More)
Answer
The front panel has the following error: ER IS. It does not let me change anything
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , AK
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
