Question about Epson Stylus C46 InkJet Printer
Epson stylus c45
My printer doesnt operate but the green and ed light keeps on blinking. Trouble shooter said that parts inside of my printer are at the end of its service life
  • 28 more comments
  • Anonymous Dec 21, 2007
    In my printer red and green light flashing alternatly, Trublshuter's say Parts Inside my printer are end of life or required service
  • rahimim Jan 09, 2008
    the green and red lights keep blinking..non of the test can be done and it says "end of service life".non of the test print or nozzle check or the others can be done,,,i need a solution,,please help.
  • Anonymous Feb 26, 2008
    my printer is on but the green and red light keeps on blinking.
  • bhavinpat Feb 28, 2008
    my printer doesnt operate but the green and red light keeps on blinking.Trouble shooter said that parts inside of my printer are at the end ofits service life. what is wrong with it (epson stylus c46 printer). is it cheaper to get it fixed or buy a new printer.
    please help
  • Anonymous Mar 27, 2008
    both red and green keep blinking. epson stylus c45.
  • cassandrah Apr 16, 2008
    i have the same problem as the rest
  • Anonymous Apr 25, 2008
    both green & red lights keep blinking
    libby
  • Anonymous Apr 30, 2008
    printer not working. message shows as redlight blinks and parts inside are damage
  • Anonymous May 10, 2008
    Both red and green LED lights blinking together
  • Anonymous May 18, 2008
    red and green light flash machine just stopped workig
    red and green light flash machine has stopped working
  • Anonymous May 25, 2008
  • Anonymous May 26, 2008
    both lights are blinking
  • toybitz Jun 04, 2008
    part inside the printer at the end of service
  • Anonymous Jun 04, 2008
    I have the same problem red and green blinks.
    message also same parts are at the end of their service life.
  • Anonymous Jun 14, 2008
    The red and green light on my Epson Stylus C46 printer are continuously flashing alternately. The printer will not print. The inks are full. The computer says that the printer needs a service. The printer is not even one year old. This has never happened before. It suddenly came on yesterday.
  • Anonymous Jul 16, 2008
    Parts inside your printer are at the end of their service life. See your printer documentation.
  • sue-j-denny Jul 29, 2008
    green and red light keep blinking - report on printer states some components at end of their life! Needs servicing - only 3 years old! Have not done anything to resolve problem, because I have no idea what to do with dratted thing that should be functioning for ages yet in my opinion! Where does one take a printer to have it serviced? also nozzle piercing thing in black ink section keeps coming adrift.
  • ramosjun_12 Aug 04, 2008
    my printer doesnt operate but the green and red light keeps on blinking. Trouble shooter said that parts inside of my printer are at the end of its service life
  • parmesh_2 Aug 10, 2008
  • Anonymous Aug 14, 2008
    same problem epson stylus c45
  • LAHMAR2008 Aug 18, 2008
    haw to rest counter
  • Anonymous Jan 26, 2009
    my printer (epson stylus c45) doesn't operate. trouble shooter said that parts inside my printer are at the end of its life
  • ncz_12470 Jan 26, 2009
    my printer (epson stylus c45) doesn't operate. Troubleshooter said that parts inside my printer are at the end of its service life
  • vijayjohri_2 Feb 04, 2009
    vijay ashish johri
    lucknow-
  • ner569 Feb 13, 2009
    yes, the red and green light keep on blinking and toubleshooter said that parts of my printer are at its life end. Any solution for this, please?
  • Anonymous Mar 06, 2009
    printer doesnt want to work out green and red lights keeps on blinking.but it doesnt want to print..
  • Anonymous Apr 19, 2009
    hi there, after changing ink cartridges green and red lights are flashing continusely. green light turn off than red light turn on simulteniously.
    i reported this to epson and their reply is;
    Epson would like to advise that a part in your product has reached the end of its service life; this is a safety feature so it does not cause serious damage to the product or its surrounds. This part is not a warrantable service; it is a non-user serviceable part that needs to be replaced by a trained service technician.
    i also instaled SCC software but doesnt work, SCC main screen shows "error - maintenance request"
    if any one exact know than please let me know, cheers
  • engalg19 Apr 28, 2009
    my epson c45 stopped printing red color i tried to clean it manuely and automaticl but the problem still persist
    if anyone can help thanx in advance
You need to download the resetter program the counter will have reached its limit and needs to be reset, it is fairly simple.
Posted on Jan 09, 2008
    Problem Solver:
  • 9 Answers
Just use the ssc service utility to reset the cleaning counter.
you can download the ssc service utility from the google and then run it
while in the tray icon, click on protection counter->reset protection counter. a warning will pop up that have you replaced the ink pads then press yes to continue.
that will reset your printer counter and it is ready to print.
just make sure to replace the ink pads in it..
hope this helps
Posted on Mar 02, 2009
    Problem Solver:
  • 8 Answers
I had this flashing light problem and it was ok after I changed the flex ribbon cable connection from drive section (on the left side)to the moving print head.
Posted on Apr 28, 2008
Thanks .. it solved the problem...
Posted on Sep 10, 2010
I did the same thing, downloaded SSC and reset the protection counter and it solved the problem wherein its saying something is on the end of its service life.
how do i replace waste ink pads though to be sure?
Posted on Aug 08, 2010
I followed solution no2. Downloaded the software. connected my printer epson c45. Selected my printer model.Right clicked on the icon appearing in the bottom tray (where clock and other icons are available)Resetted the waste inkcounter though i did not change the waste ink pads.And lo the printer is back to normal. The red and green lights stopped flashing.Fine print job after this. Best solution. If you take to shop for repair for this work they willcharge you min Rs500. Kudos fixya and its members. good work
Posted on Jun 06, 2008
Go to this site http://inkjetprinterhelp.us/epsonSSC.html and follow the instruction. Hopefully it'll fix your printer problem. Good luck.
Posted on Mar 11, 2008
3 Suggested Answers
gwbm
  • 353 Answers
SOURCE: Epson stylus c45 (Problem)
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
for sale very cheaply on E-Bay.
Posted on Feb 10, 2009
  • 16 Answers
SOURCE: epson stylus c45
if its the "parts are at end of service error" it usuallymeans ink pads are full but don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank, search ebay for "Epson Waste Ink Tank" it comes with reset program.
Posted on Aug 18, 2009
Epson Sylus c45 problem....
you can download Adjustment program of Epson C45 From "Indoresset"Webside.
The printer have to reset wast pad counter.
Thanks
Oct 27, 2009 | Epson Stylus C46 InkJet Printer
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Office Equipment & Supplies
Epson stylus c45
most problem with printers are dirt inside. if you want to experiment, try opening the printer, usually held by snaps, if accomplished clean all contacts, cables ribbon wires, then reassemble. thats easier said than done.
Jul 07, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Epson Stylus c45 prints abruptively
green light flashing and red light is blinking cannot print
Feb 18, 2009 | Epson Stylus C46 InkJet Printer
My printer epson stylus C45 series do not print
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, post a new comment to this effect and I will provide further help.
Feb 14, 2009 | Laser 3115cn All-In-One Printer
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
C45
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 15, 2006 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
2,873 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
