Question about Belkin (F5D5231-4) Router
My WiFi problem
Alright, im able to use it by myself on my PC which is connected by cable, but my Nintendo DS Lite and my sis's PC(Vista) is not able to. we don't have an extra cable so my sis has to wirelessly connect. My DS has the same problem. Im able to detect the Access Point but cant access the internet. I cant troubleshoot it anymore since i have ran out solutions.
  • nicknme tkn Jan 05, 2008
    my problem is that my wired desktop with xp can surf the net through the modem just fine. my laptop on the other hand is only making a limited connectivity to the network and not allowing me to surf the net. i phoned belkin but they could not even fix the problem. any body have any clues?
  • 556 Answers
Please confirm the manufacturer and model for the router being used? The router in the heading of this message does not appear to have wireless capablity.
Secondly in terms of your sisters machine assuming it has an ethernet port have you tested it using the cable just to make sure there are no (software) firewall issues on her computer affecting access to access the internet.
Sorry I have no Nintendo DS knowledge specifically. I may try to research the issue after the router and laptop issues are resolved.
Are there any other wireless devices (computers) currently working correctly with your wireless router/access point?
Posted on Dec 15, 2007
  • david Dec 15, 2007
    Sir;
    How can you rate this in any way as it clearly is not a solution -- it is a series of questions to determine the nature of your problem in order to recommend a solution. You have asked for assistance yet dismissed my help without answering a single question and giving me a chance. I believe I deserve a chance to recommend a solution, don't you? Even if I only fix the laptop problem -- once that is done another person may be able to address your nintendo DS issue easier because the laptop issue was resolved. Another possibility is that the Nintendo DS problem is resolved when the laptop problem is resolved -- they have the same problem.
    Sir, I am sorry, it is now apparent that you do not want my assistance. My previous comment was not to secure a rating change but was a serious attempt to offer you assistance. Please put the rating back if that is what you really believe.
Cant conect me DS light to my Wi-Fi
http://www.nintendo.com/consumer/wfc/en_na/ds/wrInitialSetupHelp.jsp
If fail:
Make sure that the wifi settings you have are connect.
See if you are able to connect to another wifi connection.
-Make sure you know the wireless settings for the other wifi connection.
-You may also want to try to connect to an unsecured wifi.
Dec 17, 2012 | Nintendo DS Lite
What do i need to go on wifi with my ds
You can only connect to WiFi in certain games (such as Pokemon) and it will ask you to connect to WiFi ingame.
There is nothing you need to connect, just a DS Lite and a wireless router.
May 18, 2011 | Nintendo DS Lite Console
Im trying to get wi-fi connection on it and its telling me that "The access points security settings are not supported by the nintendo ds'
That means that the connection you're trying to connect to is probably a WEP-encrypted WiFi source. The Nintendo DS Lite cannot support that format of WiFi, however Nintendo has posted a very detailed and visual step-by-step guide in how to resolve that here
Just scroll down to "My security settings are not supported or are not compatible" and follow the instructions.
Good luck.
Apr 03, 2011 | Nintendo DS Lite Console
Nintendo DS Lite Turns on sometimes, but not every time
It may be a bad DS or if you have a game in before the DS fully loads the game's connection is stopped somehow.
May 11, 2009 | Nintendo DS Lite Console
Ds lite connection
Have you considered changing your router from WPA to WEP? That would solve your problem with getting your DS online, although it would reduce the security of your home network. But some security is better than none. As far as the WiFi Max dongle, that's just a simple version of a wireless router and since you already have one it's kind of redundant. You might want to put it up on E-Bay and see if you can make some of your money back.
Feb 06, 2009 | Nintendo DS Lite Console
Touch screen wont respond
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Jan 29, 2009 | Nintendo DS Lite Console
Nintendo ds lite
Doubtful, though I've not had one with a gimped antenna so I can't say for sure...
Probability is very high that failure to start is related to the ribbon cable(s) not being seated properly into the connector(s). This is a common issue during re-assembly. Often, these cables LOOK like they are re-seated properly - but they are not.
First suspect is the ribbon cable that passes through the hinge. Where it connects into the top board is where I encounter problems often. If this cable is not seated deeply enough into the connector - and perfectly perpendicular - your reassembled DS will NOT boot.
I always temporarily snap everything together and test boot prior to screwing everything back together. Even with care and experience I have to go back to this connector and re-seat the cable about 1 out of every 2 times.
Good luck...
Jan 14, 2009 | Nintendo DS Lite Console
No wifi connection for ds lite
Did you try to set up your Wi-fi connection settings or your not in a good Wi-fi connection zone.If that doesn't work mabey not made by or for nintendo.
Dec 26, 2008 | Nintendo DS Lite Console
DS Lite flight mode?
The Nintendo DS LIte itself is in flight more or it's called "not connected". Unless you activated the Picto-Chat or any wireless games (Download Play, WiFi), the nintendo ds isnt emitting any wireless signals.
Aug 09, 2008 | Nintendo DS Lite Console
Im trying to get my ds online to my router
Hello irishguyroy, I Have a DS and It Is Connected To Wi-Fi. The Only Way You Can Connect to Wi-Fi is through a game with wi-fi. if you need more help, leave me a comment on my help site:
www.rosebetts-at-fixya.piczo.com
Dec 29, 2007 | Nintendo DS Lite Console
Belkin (F5D5231-4) Router Logo
106 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
