Question about Nikon COOLSCAN 5000 ED Film Scanner
LS5000 ED with slidefeeder sf 210
While scanning a number of slides (for e.g 40 slides) the autofocus seems to get deadjusted for some slides. If I scann these unsharp scanned slides again in a single scann they are scanned perfectly. I´am using the Nikon scann software 4.0.2. And because I ticked the option "autofocus for every slide" I am under the impression that the scanner will do a autofocus adjustment before scanning the next slide.
Did anyone discover a similar problem or has an idear how to solve it.
Thank you for your help.
Regard
Werner
  • 2 more comments
  • Anonymous Dec 23, 2007
    I have the same problem, my scaner can't get sharp pictures when it is on it's side as required with sf-210.
  • Anonymous Sep 07, 2008
    yes I have the same problem to - not good.
  • happy_trails Dec 31, 2008
    I am having the same problem as well. I have a new Coolscan 5000 and an SF-210 slide feeder. The first 10 -15 slides will be focused correctly and then it will be out of focus for the remaining 25-30 slides. I have my scan options set to autofocus on every slide, but it does not look like that is working correctly. My email is happy_trails@juno.com
  • Anonymous Feb 23, 2009
    I have the same issue, and might have a potential solution for mine, although I haven't tested it yet. After I switched to a second set of slides, it complete lost the ability to focus (and you can hear it try and try to get it right). Just out of curiosity, I flipped the slide around so the emulsion side is facing away from the pressure plate on the 210 feeder. It was able to focus immediately on the first try. I'm thinking something about the Kodachrome slides cause this issue. I am investigating further to see what the trade-offs are on my approach.
Hi there I had the same problem with auto focus sf-210.
If tried many things to correct the problem and what I found was that if you you put a small book halfway on the opposite site of the power button then I have maybe 1 or to slides out of focus and the other 35 slides are perfect ! (I used it with HAMA slides other slides I didn't test )
Hope this wil work also for you,
Paul
Posted on Aug 15, 2009
Nikon ls 4000 ed
Now thats as daft as the last premium problem I answered.
Seriously though, have you got another firewire device that you could plug your port into to prove the port. Or have you another port to plug your device into to prove the failure point one way or another?
Oct 10, 2007 | Nikon LS5000 Film Scanner
Tip
Nikon Coolscan IV ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan IV ED?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan IV ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Coolscan IV ED Film Scanner
Launch Nikon Coolscan, but browser/scanner window doesn't open
I think the scanner may have got confused and be expecting another adaptor to be connected. If you slot in the single slide adaptor, wait until all the scan functions become active on-screen, then remove that and insert the SF-210, you might find it works OK.
Jeff Underwood 1scan.co.uk
Nov 16, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Bearcat BC-210
The Bearcat 210 Manual specifically states that the lowest freq available is 32MHz.
Jan 04, 2008 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Tip
Nikon Coolscan V ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan V ED?
Try this solution:
The slides will fan out nicely, and your Nikon CoolScan V ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon CoolScan V ED Film Scanner
Tip
Nikon Super Coolscan Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 4000?
Try this solution:
The slides will fan out nicely, and your Nikon CoolScan will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Vertical banding
Well not a complete solution but. . . It will help. 1st Digital Ice will screw up when trying to use it's infrared on Kodakrome so either don't use it or better yet don't use Nikons scanner utils. I use both Silverfast and Vuescan and will never look back yes they both solved this but the real issue is inside but do download a trial of vuescan before you go any further.
Your problem might be a cleaning of the mirror since mounted slides might "curve" in the frame differently and accentuate this issue. Look at this site I clean mine once every 6000 scans which works out to about once or twice a month.
I also recommend (a must do) is run your scanner on its side if you own a sf-210 feeder you already are so look at how this unit attaches on nikon's site or in your manual and do it. This way the guts are on their side (mirror not lying almost flat for all the dust to fall onto it).
Good Luck Morphoto.ca
Jun 07, 2007 | Nikon Super Coolscan 5000 ED Film Scanner
Tip
Nikon Coolscan Slide Feeder Jam Solution Do you find your older slides,...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan 5000?
Try this solution:
I hope that helps.
on Apr 09, 2010 | Nikon Inc Coolscan 5000
Tip
Nikon SF-210 Slide Feeder Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan?
Try this solution:
I hope that helps.
on Apr 09, 2010 | Nikon Sf-210 Slider Feeder For 5000ed...
Tip
Fix that Jamming Slide in your Nikon CoolScan 5000ED / SF-210 Slide Feeder
I balked when someone whispered this tip to me; the thought of putting foreign objects into my Nikon CoolScan 5000ED slide scanner with its SF-210 slide feeder seemed asking for trouble.
After about a thousand slides worth of experience, and many batches that seemed to jam every other slide, I gave it a try and boy did it do the trick.
The SF-210 slide feeder works flawlessly with newer, thicker, plastic slide mounts, but if you are archiving and digitizing older, cardboard slides like I am then here's what wasn't printed in the CoolScan user's manual:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below.
I hope that helps.
on Dec 04, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon COOLSCAN 5000 ED Film Scanner Logo
400 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
David Darrow
Level 1 Expert
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
