Faulty amp hi i have a technics amp wich powers up fine but then the safety light comes on, can you help with this? thanks pete
    Problem Solver:
  • 8 Answers
Could be in the remote wire at least thats what to hope for. did you wire it off the cd player or off the hot wire. i had a boss doing the same thing but wouldn't stay on b/c i wired the remote off the hot. if that ain't it then and i hate to say this your power supply may not be adequate, you could try using heavier gauge wire. if that didn't do it then your alternative would be get a smaller amp or get a bigger battery with high output altinater
Posted on Dec 15, 2007
I have no power at all turn key no lights or no crank
Hi, Pete before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
The Venturers Yamaha Venture Technical Support Library
OEM parts for Yamaha
May 09, 2012 | 2005 Yamaha Royal Star Tour Deluxe
Mower ran good. stoped running while using. turnes over good, gas good, no spark new plug. 12 volts to red & white wire engine at dieode none after dieode.Help Perry DePalmer
Please could you check under the seat for a safety switch wich will stop the spark if not depressed. It might have moved or been knocked but to please check this first and come back to me .Thanks
Jul 06, 2011 | Mtd Garden
Crown xs 700 power amp when powered comes on briefly then fault led illuminates,when ch2 is diconnected internally amp comes on with no fault condition indicated,i think the amp has had a load problem,more...
First confirmed if your speaker and wire are not shorted. Once it is in good condition then it has a big chances that you have a faulty output IC. This is quite technical and I've advice to send it to qualified service center to isolate the problem. This is fixable.
Thanks for using fixya.
Jan 19, 2011 | Crown XS700 Amplifier
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
Apr 04, 2010 | Technics SC-DV290 System
Hi, i have a 600w fusion amplifier in my house running on a transformer. when i turn it on the red light comes on but when it changes to green the transformer shorts out. its not the transformer thats...
How many watts is your power supply capable of supplying to a given load. There could be a problem with your amp. The quiescent current should be in the high mA to low A range which in no way would cause your supply to overload.
Dec 20, 2009 | Car Audio & Video
Pioneer vsx-604s power problem
The problem is not likely to be the power supply, but shorted output transistors. If you do not see the standby light, then the problem is likely to be either an open standby transformer (primary) or perhaps the 5V regulator transistor. You have given very little info to go on here. Can you provide a little more info on what happens when you try to turn it on?
Nov 02, 2009 | Pioneer Audio Players & Recorders
My technics clss A amp cuts off ones i incease the volume to a quater,it just switches off the speakers.but the amp says on,i have to turn it off & on again to on the speakers,i suspect the STK.plz...
You have a blown power transistor, they come in pairs you need to replace both. You may have a safety relay that is cutting off the power amps because they are drawing to much current., that is why it appears to stay "on".
Oct 01, 2009 | Technics 13.5VDC 1.2A Class2 Power Unit...
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
37 people viewed this question
