Question about Kenwood eXcelon KDC-X679 CD Player
Face ribbon replacement
Do you have a you tube video or know of some way I can get a procedural approach to replacing the ribbon to the front face on the kdc-x769? I was able to do it on my kdc-x711 but im not sure exactly where to start with the x769. any help would be greatly appreciated. thank you
SOURCE: Kenwood KDC-X711 not working
Got the same problem, try taking it out and throwing it on the ground a couple of times.
Posted on Apr 24, 2008
sumthin
  • 71 Answers
SOURCE: I have a Kenwood excelon
Bad sensor, or microprocessor. Repair or Rma
Regards Paul
Posted on Jun 13, 2008
  • 4 Answers
SOURCE: CODE IS LOST AND STEREO WONT COME ON KENWOOD KDC-X769 CD RECIEVER
you have to turn the unit on with the remote so the display is on the code entry screen, then press and hold the toggle button on the bottom right side of the screen for 10-15 seconds, basically hold it till the unit turns back on.....
Posted on Sep 06, 2008
  • 105 Answers
SOURCE: what is the security code for this kenwood car
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Posted on Jul 15, 2009
kenw392
  • 2226 Answers
SOURCE: when i turn the car on the control panel on the
you may have a bad face position sensing lever inside the deck, or bad gears. it could even possibly be bad flexible cables.
Posted on Jun 21, 2010
Ice dispenser replacement
I believe you are asking about repair and replacement of Click Here=> 12001991 Ice Dispenser Repair Kit if wrong please let me know as the ice dispenser repair may also be confused with another function within the dispenser components. Ice Makers are also considered part of your dispenser component's. Below is a quick tutorial of how and what tools will be needed to remove the front facing so you can reach the parts behind the dispenser facing. If the You-Tube Video below is not here when I post this solution please click=HERE
If helpful please rate this solution. Should you have any questions I will be here to answer any questions you have, Thanks Sea Breeze
Jan 07, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hello sir i haw n95 no light in disply
If you are not having light on your nokia n95, then it means the florescent tube of your is bad, the solution is for you to replace the screen of the phone. To replace the screen of the phone, follow the steps below:
  1. First remove the battery cover, battery and memory card. Move the slider down and remove the two screws you see.
  2. Now move the slider up and remove the two screws at the top of the phone,
  3. Run your fingernail along the edge of the join of the front cover to unclip it.
  4. You should now have the front cover removed. The keypad should be loose as well.
  5. Flip the keypad part back to access the ribbon which connects the LCD to the phone.
  6. To remove the ribbon, flip back the metal hinge and then simply pull the screen back and the ribbon will be released.
  7. Pull the LCD in the direction like you are sliding the screen up.
  8. Your phone should look like below and you can replace the LCD.
  9. Reverse the whole procedure for reassembly.
If you are not familiar with such technical activity, i will suggest you ask a friend who is familiar with it to assist you in carrying out the job.
Hope this information helped.
Jan 09, 2011 | Cell Phones
MY PS3 DISC DRIVE WILL NOT READ ANY DISCS
I have fixed many with this problem. Which can be hard to diagnose as some may think just the disk motor is burnt out as the disk will not spin. The disk will not spin if the laser does not engage. I order the lasers for about $75 US. Disasemble the unit firt so you know which laser part # you will need. It is not brain surgery but you will has to be careful with power plugs and ribbon cables. Lots of videos on you tube to help. Thanks
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Replace LCD monitor on Sony DSLR a350
The You-Tube video is useful. http://www.youtube.com/watch?v=dP0Yr4YXM9Y
Care must be taken when removing the ribbon-cable connector from its mating half on the camera ribbon-cable.
The black strip on the mating connector has to be flipped back, away from the display ribbon, to release the display ribbon.
Then after locating the new ribbon fully home, the same black strip has to be flipped forward in the direction of the display ribbon and pressed down to clamp this connector in place. All this is shown, but quickly in the video.
Do not touch the bare surface of the new display or the inside surface of the removed display protective surface which has an optical coating which easly shows fingerprints.
Aug 23, 2009 | Sony Alpha DSLR-A350K Digital Camera
Need to replace front left cv axel
Best approach is to acquire a repair manual for that vehicle. Pep Boys or similar will likely have one..
Apr 28, 2009 | 2004 Kia Optima
Air condtion
the orfice tube is located in the lower condenser hard line. once you screw the lower line youll be able to see it.
Mar 18, 2009 | Scosche Industries Scosche Gm1482b...
Need to change crt's on a sony kp51hw40
Let me know exact model number of Sony TV to provide you service manual.
Service manual has all technical details about CRT replacement.
Jan 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Cannot eject or turn off power on my pioneer deh-p8600mp
when you take the unit out of your car and looking at the top of the unit there are two black screws. Remove those then remove the entire cd player cage by the 4 CHROME screws on the four corners of the cage the two in the front are in the two holes in the ver front (**use magnetic screw driver for this**) then disconect the two wire plug and the ribbon cable from the bottom of the cd player cage **BE GENTLE** there are two black tabs on either side of the ribbon cable. THEY ONLY MOVE ABOUT 1/8TH ON AN INCH using a jewler flat blade screw driver gently slide the clip out to un crimp the ribbon cable then once the cage is removed you can open the face. To open the face there is a white gear wheel on the rightn hand side of the unit you can rotate it with your thumb with a little effort. Rotate accordingly..... at that point you shouldnt have any problem but let my know if you do..
Dec 10, 2008 | Pioneer DEH-P8600MP CD Player
Shutting Off
the usual repair for a morotized face plate with symptions of no display, some buttons working or no buttons working & sometimes even the faceplay not moving, is the ribbon backthat connects the main unit to the face plate. Sometime you might be able to see the gold/yellow flat ribbon as the face plate flips. it's not too difficult to cange but it takes patience. the cables run around $15 to $30.00.if you replace it yourself, watch out incase the spring for the ribbon tension unwinds. good luck
Dec 14, 2006 | Kenwood eXcelon KDC-X679 CD Player
Kenwood eXcelon KDC-X679 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
