Hello, There is absolutely nothing wrong with your car. It's actually keeping you safe! If the outside ambient temperature is +37F or lower, your car knows this and gives a warning for possible black ice conditions. Lots of people wonder the same thing, next time it shows the warning, note the outside temp to see if it's below +37F.
I know of no such warning light on the 2006 Chevy Equinox that shows a wrench with an engine. The wrench with an oil can beside it means that there is scheduled maintenance required as listed in your owner's manual. You will see this when it it time to change the oil. The light that shows an engine is the Check Engine light and comes on when there is a problem with the emissions system. It requires that the ECU be scanned with a scan tool to retrieve the code that has been set. A trained professional will use this code to repair the problem.
this is for the tpms "tire pressure monitor system" chances are you have lost to much pressure in one tire so this system is warning you of this fill the tire with air you should be good take it to a tire center and they can help you if the light does not go off
If it is yellow and looks like a tire it is the flat tire light, and you should check his tire pressure. if it is a yellow triangle with an arrow going around the triangle with a exclamation point in the middle this is your DSC or ASC and if it is on all the time these features are inactive and you should hit the DSC/ASC toggle switch to the right of the drivers window switch. If this symbol just flashes briefly this means the DSC/ASC is presently activating. thest are the tow that I can think of, I hope this helps.
