Question about Aiwa Pavit AZ-BS32 32 MB MP3 Player
Factory reset how can i reset my AZ-RM32 ? to original factory setings ? i did format it and now the original program can't find it
0 characters
1 Points
Reset to original settings
Hello, Factory Reset is done by turning the phone off, holding the volume up button, holding the home button and then holding the power button till the phone vibrates and you can let go of the buttons. Use volume up and down to move through options and power button to select (don't have to hold, just press once). Select "wipe data" and then "factory reset". Select "yes" to delete all user data and wait for format to complete. Then power off then on and it should be back to original settings. Hope this helps.
Oct 21, 2014 | Samsung Galaxy S III S3 SGH-T999 4G White...
How can i reformat my go gear philips? back to its original format... delete all applications i downloaded.
There's a reset button on the back of the player which takes you back to factory settings and erases all that is stored. Make sure you got all that you want off it before you do it tho..
Mar 02, 2011 | Philips GoGear SA5285/37 Digital Media...
I have a used Sony Walkman NWZ-E438F and want to start from scratch. If I press the reset button in the back, will it delete the playlists and still keep the operating program?
Hi bkil105498,
Pressing the Reset Button will probably not delete the playlists and data, it will probably just restore the factory settings. To delete everything, go to Settings--> Common Settings--> then Format. In neither of these ways can the operating program be deleted, only the data and customizations.
Hope this helps.
Dec 30, 2009 | Sony NWZ-E438F Digital Media Player
I have a mp3 2025. I am trying to delete songs but when I plug it in to my pc all I get is some program for photos
try to format the mp3 player to reset it to the factory settings.this will delete your music and everything else but keep the also sounds like the files are not the right format .right click them and rename the end of the name type .jpeg .gif
Jun 28, 2009 | MP3 & Digital Media Players
Coby MPC 895 - Some MP3 format songs will not play
i suppose your player is under a virus attack. clean it with an original antivirus software and also your pc too.reset your player to original factory settings. remember this will erase all your data in the device. so you can make a backup before formatting the device. that will solve your problem
Jun 05, 2009 | Coby MPC895 MP3 Player
I cant put songs on my sansa
it is look like it is psword protected ,or has some kind the buton wich does not let you put/remove song's fom it.try to find that buton or rest to factory seting, format the player.
Jan 14, 2009 | SanDisk Sansa m250 MP3 Player
Screen says boot error
Try to reset the device. Reset it to original factory settings and try again.
Sep 26, 2008 | Sony Walkman NWZ-B105F MP3 Player
HP mp3 player troubleshoot
There should be a reset button on MP3 player. Hold this down and reset to factory settings. If not, go to the manufacturer's website and type in "reset to factory defaults." It will show you how.
Jun 13, 2008 | HP MP3 & Digital Media Players
Pavit won't play
You have to reset it back to factory settings because you deleted with the original demo music some files needed to start the built-in player. So do the factory reset after you restart your Pavit MP3 Player. Then copy you music and play them.
Feb 05, 2007 | Aiwa Pavit AZ-BS32 32 MB MP3 Player
Aiwa Pavit AZ-BS32 32 MB MP3 Player Logo
Top Aiwa MP3 & Digital Media Players Experts
Gyula Lacz
Are you an Aiwa MP3 and Digital Media Player Expert? Answer questions, earn points and help others
