Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Troubleshooting for monitor
When i am not working with my computer i turn off the monitor ,if this happends system will restart automatically
    President:
  • 2,351 Answers
Could be a faulty cable in connection with the power button on the monitor. When you turn off the monitor it sends a surge to the PC which see's this as a surge and restarts the system. Try to change first the cable, borrow one if possible. Than borrow a monitor. You'll which is bad.
Posted on Dec 16, 2007
I got this computer from a friend of mine, and he hasnt used it in several months. I plugged the computer in, and the monitor and turned it on. It started up fine, I logged in, and then it asked me if it...
your computer have 2 complaints one. your computer have over heating problem of your cpu. so just remove heat sink and fan of ur cpu and clean after u must put 'heat sink compound on your cpu' after you can install heat sink back.
two, your computer is banded microsoft thats why when u loged on your pc. will ask automatic update so first you must log in to safe mode of xp ..click f8 button when u boot ur computer and login to safe mode.after you can install windows genuine remover you can download it from this site...http://www.brothersoft.com/removewga-download-62674.html..
Oct 06, 2011 | HP Hewlett Packard Pavilion a1016x PC...
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only...
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
Jan 03, 2011 | Acer X163W 16" wide format TFT Screen 8...
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
My PC restart in every 2 hours why ?
automatic updates could be turned on, might have a system failure, so it restarts, could be a virus or spyware, could be a hardware problem. its hard to pin point the problem. e-mail me the specs of your computer and i can help you more with troubleshooting your problem tech2call@gmail.net
Jul 14, 2010 | Compaq Computers & Internet
System defaults to "Automatically fix file system errors"
Open my computer and right click on your local drive click properties click tools click check now remove check from Automatic fix file system errors start same with the more drives
Jul 04, 2010 | Sony Computers & Internet
My comuter w0n't stay on
o.k. unfortunately this may mean your monitor is in need of a service repair technician. The same thing happened to my hanspree monitor. Lucky for me mine was still under warranty. How about yours? how old is it? If it is not over 2 years old you may still have a warranty on it. please also try this: --------------------------------------------------------------------------------------------- so, it automatically shuts down? try turning on your pc and do not wait for it to boot to windows. instead, immediately tap on F8 key several times as soon as you see that there is power. it should lead you to Windows advanced options menu, highlight disable automatic restart on system failure using your down arrow keys then press enter. it should start normally or if problem still persists, try safe mode instead. it would isolate the issue. if in safemode it will still shutdown automatically then you need to replace your harddrive. if not, then you should just reinstall your operating system to have your system work fine.
Apr 10, 2010 | Compaq Presario 5000 PC Desktop
When turn on BIOS wouldn't load until i press restart
you are having problem with the connector i;e power button try at some good repairing shop
May 26, 2009 | Intel D945GNT Motherboard
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
