Question about Fuji FinePix A330 Digital Camera
Write error i keep getting write error every time i try to take a photo. I have formatted and this doesnt help :(
  • 1 more comment
  • Shellardson Dec 16, 2008
    How do I fix it? I too, keep getting" write error" every time I take a picture
  • pearl1276 Jan 01, 2009
    I have same problem. write error notification occurs after photo is taken. Seemed to become a problem after using software to read the picture card. The card is an H type 2GB XD picture card.
  • Julia1958 Feb 17, 2009
     after formatting fugi finepix a330 - write error comes on. I cannot locate another one to "borrow" to save to files.
  • 749 Answers
The camera should be the one to format the removable-memory, if you use a computer, well that is what you get. The best thing to do borrow a memory the same as yours and copy it to your memory. Then erase contents of folders only, leave the folders empty... This is causes an error if folders are erased from the memory.
Posted on Dec 15, 2007
Using Nokia C1-01. I have selected Photo and video storage to Memory Card. when i open the camera, i get error, Memory full, where as in gallery i can see 735MB of memory still available on memory card. I...
Free memory is still usually required in phone memory to temporarily store the photo you take, so try clearing the phone memory. If that doesnt work, try using another memory card or format the existing one after backing up your data.
Jul 03, 2011 | Cell Phones
Memory card error
If you get a message on your camera such as "Memory Card Error" AND there are no photos that you want still on the card, the first step is to format the card through the camera menu (Note: if you have an xD card, once you re-format your card any photos cannot be recovered.). Read your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
If you do have valuable photos on the card, then DO NOTHING (do NOT format the card, do NOT take any more photos). You need to undertake a photo recovery. For options on Photo Recovery, click here. Once you have recovered your photos and archived them, then reformat the memory card through the camera as outlined above.
Keep us updated (remember to rate this answer).
Dec 22, 2010 | Canon Cameras
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Memory card error - After taking about 300 pictures on a 2 Gig Kodak SD memory card. I get a message on my Canon camera that says '' memory card error'' I tried to put the chip in a differant camera but it...
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're inexpensive.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but the file structure will eventually corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again. Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Nov 16, 2009 | Canon Cameras
Card error
Take it to a camera store and ask for a data recovery. Once the data has been recovered, format the card in the camera and you should be fine.
Aug 10, 2009 | Cameras
Clean or format card error on Olympus XD card
my camara showing error message that clean card or format card,
i have some important photo in memory card so i can,t format the memory card.
while i am connecting with USB cable it,s showing syntex error
help me to retive the thw data..
txs...............
Jun 05, 2008 | Olympus Camedia C-350 Digital Camera
Card Not Initialized Error
Get the photos you want to keep off the card, and reformat it in the camera. Just deleting pics won't help. More than likely corrupted memory, and needs reformatting, Has worked for me several times.
Mar 13, 2008 | Fuji FinePix 6800 Zoom Digital Camera
CARD ERROR ON OLYMPUS 710 STYLUS
I repeatedly removed, ref-formatted and replaced the card.  I did this 3-4 times and, while the battery did run down rather quickly, the card error problem seemed to be resolved.
I took some sample pics, download to comptuter, replaced card in camera and was delighted to find them still visible, and no card error message came up.
I hope this is a permanent solution.... and will have to check again when I have a chance to download again.
Oct 23, 2007 | Olympus Stylus 710 Digital Camera
Deleteing photos from the little cd's
you can delete photo's till you finialize the disk
Jan 30, 2007 | Sony Mavica MVC-CD400 Digital Camera
Fuji FinePix A330 Digital Camera Logo
75 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
