Question about Teac DUAL CASSETTE A/R 110/220 Single Dual Cassette Deck
My teac V 33 stereo cassette deck is not functioning.
During servicing the PCB(circuit) was tampered with & it is not functioning.Can anyone tell me how to obtain the circuit diagram of this model with all details,& any other suggestions to fix this problem.
    Genius:
  • 1,175 Answers
Hifiengine.com might have it.
Posted on May 05, 2008
How to replace the belt on a Teac W-750r cassette deck
In all the years I have been in tape decks repair I have never seen one. You either have to work with an experienced Technician or do it yourself using common sense. Going to college gives you a degree and knowledge of parts it dos not tell you how to fix anything. That may be why I work on some Nasa Engineers tape decks.
Jan 06, 2014 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Repair manual for TEAC R-H500 Cassette Deck?
I think I got mine from owner-manuals.com for about $5.00
http://www.owner-manuals.com/index.php?main_page=index
Jun 08, 2013 | Teac R-H500 Dual Cassette Deck
My Play, Pause, and Record button will continuously blink on and off, which prevents me from opening the cassette door using the eject button to play a tape.
That would be me at Skywave Tape Deck Repair- maybe I have contacted you already through Thumbtack.
I can not say more here but if you search for tape deck repair in Chicago you no doubt will come across me sooner or later.
The only other person you would be qualified would be Russ Bachmann at New Jersey Factory service. We both worked at Teac factory service facilities and rose to high ranks at those facilities.
Jan 18, 2013 | Tascam 122MKIII Single Dual Cassette Deck
I have had my 1991 lexus ls400 for a couple years now and I've been using the cassette deck in the stock stereo unit all the time by using one of those cassettes with the 3.5mm headset wires coming out...
The tape deck in the unit probably needs to be fixed. Even though you are using an artificial tape supplying a signal to the heads, there are still motors and belts running in the unit if it thinks a tape is in there. Now a belt or a motor has failed and the deck will not stay in tape mode. Thus pulling the unit out of the dash and having it serviced will be required to use this I pod function. There has to be easier ways to do this- I would consult Crutchfield about it.
Nov 08, 2012 | Audio Players & Recorders
Teac w-505r How good was this unit new
It is a Dual cassette which is one mark against it and it is a light weigh deck. These were made for profit purposes not for a long lasting cassette deck. As I have said from the day they came out stay away from Dual cassettes as they are nothing but junk and you are getting this info from a repair technician of 40 years that has mainly worked on tape deck. I also worked at Teac Factory Service in Arlington Heights where I got to the rank of Lead Technician.
You want a good deck- V900X, V1RX, C-3RX, Z6000, V2RX are some that come to mind Tascam 122B is another.
If you need more help- I run a repair service.
skywavebe@sbcglobal.net
Sep 06, 2012 | Teac W-505R Single Dual Cassette Deck
I have a TEAC A510 cassette deck the logic controller is bad. the IC chip is manufactuered by Misubishi the number on the chip is N54410P 3YE3, can you find this IC or tell me where to find it and how...
HI,
You have to check with the part number of that ic to get the exact one . The numer you spesified is not the part number . As i dont have the service manual for this model I am not able to give you the part number. I have added Two link here which will lead you to the service manual for Teac A-510/A-500 (Both are same ). Get the manual and find out the Part Number for the specific IC in the part list
Then serch with the Part number. For any more assistance Feel free to contact me through fixya
http://www.teac.owner-manuals.com/A510-service-manual-TEAC.html
http://uk.ebid.net/for-sale/teac-a-a-cassette-deck-service-manual-49086786.htm
Ajin
Dec 10, 2011 | Audio Players & Recorders
Instructions to replace belts on teac cx650r stereo cassette deck
The replacement of belts on any deck requires you to dismount the transport section and take thrust plate off as well as other mechanical parts to get to the belt location. It is at this time that the reel table should be removed and rebuilt as the take-up torque due to old felt will be excessive and you don't want to have to go in again. Oiling of the Flywheel bearings is also good to do at this time.
If you can not do it I work on deck as Skywave Tape Deck Repair near Chicago. That is one option. There is another service provider in New Jersey.
Jan 22, 2011 | Teac Audio Players & Recorders
Teac cassette deck records at very low volume
Tape decks have a record amp, depending on the age of the machine it will probably be an IC. Yours might have failed. See if you can identify it or try and get a C diagram. To locate it follow the leads from the head. If your lucky it might have 'Rec Amp' on the board. Their maybe a preset marked 'rec level' for each channel. The (IC) box with legs - near them will most likely be it. Don't adjust the presets unless somebody has tampered with them before. (they will look to be sitting around the middle if they are OK).
May 30, 2008 | Audio Players & Recorders
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
335 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
