Question about Actiontec (GT704WG) Router
Mp3 rocket says i have a firewall
I can't connect the mp3 rocket, it says i have a firewall after i tried turning off the firewall & adding the port# that mp3 provided. can someone help me please??
0 characters
1 Points
I tried to port forward for game ranger but it didn't work maybe i forwarded false. I have d-link DIR 300 can u help me plz how to port forwarded on game ranger. NB: when I try to host or join a game it... has a great reference for most routers including yours. Verify what you did matches the instructions on this site. instructions on how to configure DLink DIR 300
If you still cannot connect, verify GameRanger is allowed through your firewall. If you are using the Windows Firewall, temporarily disable it and see if you can now connect and host a game.
Windows 7 - how to disable Windows Firewall
Oct 03, 2013 | D-Link DIR-300 Wireless Router
I am trying to get on facebook at my school and how would you get it un blocked bios, command center, prompt, and proxy servers are blocked too
If your school has blocked such time-wasting web-sites, when using any of the school's computers, you risk suspension or expulsion from school, if you try to circumvent their blocking.
So, assuming that a cell-phone works inside your school, bring your own computer, and buy a "rocket stick" (it connects to the Internet via the cellular network), and connect that rocket-stick to a USB port on your computer. Voila -- "bring-your-own" Internet access. Monthly fees apply.
for details about how to purchase a rocket-stick.
Sep 21, 2010 | Routers
Warcraft III: Frozen Throne - Can't host even though followed directions on portforward an etc., any solutions?
try with firewall disabled on computer? Some routers also include firewalls and require ports to be added to exception in firewall on router as well.
If that does not work set up computer as DMZ host in router configuration and see if that works.
Apr 16, 2009 | Arris Wireless G Broadband Router (wr850g)
My F5D7230-4 Belkin Router Virtual Servers power forwarding broke
Hi there!
Have you checked the Windows Firewall settings? If it is On, try turning it off and attempt the connection with RealVNC. If the problem persists, try adding an Exception to the Windows Firewall, just as an added troubleshooting measure.
Click Start, navigate to Control Panel, double-click Windows Firewall, and open the Exceptions tab. Look for a RealVNC entry. If you don't see one, click the "Add Port" button, type RealVNC as the entry name, and 5900 as the port number. Select the TCP radio button, click OK and then OK once more. Attempt the RealVNC connection again.
I hope this helps! Feel free to reply with results or further questions.
Feb 18, 2009 | Belkin (F5D5231-4) Router
Open NAT with Thomson (Speedtouch) TG585 v7 Router
First, try adding a wireless card to the Xbox, run the wireless off of the router OR if you have multiple connections (broadband, should be an "In" port, and several "Out" ports) Try connecting your PC and you Xbox through the "Out" ports, with the cable modem cord hooked into the "In" port...
Feb 02, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Port forwarding
try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
Oct 22, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Won't let me connect to PlayStation 2 online
no need to turn off the router's firewall... just forward the ps2 port number on the router. make sure you manually assign static ip address to your ps2.
Jun 25, 2008 | NetGear FVS318 Cable/DSL ProSafe VPN...
TEW-452BRP - can't open a port (forward)
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Feb 23, 2008 | Trendware TEW-452BRP Wireless Router...
Open a port for a certain program
hi mike,
this router has its own firewall, although i don't think its a good idea to turn off the firewall
google the port that limewire uses and then use portforwarding on the router.
you can start by turning off the firewall on the router to see if it works. if it does then perrhaps just allow limewire to passthrough your firewall at the router.
good luck
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Actiontec (GT704WG) Router Logo
2,096 people viewed this question
Top Actiontec Routers Experts
 C. Dante
C. Dante
Richard Schabler
Are you an Actiontec Router Expert? Answer questions, earn points and help others
